72 | Fuel Tank and Sending unit details
Old November 15th, 2018, 11:33 AM
Brians1's Avatar
Need some assistance on the following question please:
I need to replace the fuel sending unit and while im there im going to replace the fuel tank and the various fuel lines, straps, and grommets.
Motor is a 350 now (455 is on engine stand getting finished). I am running the standard manual fuel pump on both motors
When I look at sending units I see 2 options...3/8 inch only or 3/8 inch with 1/4 inch return line
So which one do i need ?
Brian
Brians1 is offline
Old November 15th, 2018, 12:06 PM
Brians1's Avatar
I think I found my answer....searching forum threads
"Yes, I'm looking at the 71 Assembly Manual (which is almost 100% identical to the 72). Section 8, page 104 is the non vented system that was used with the 350 engine cars. "
So my current 350 setup has a single line sending unit, and when I get my 455 installed, I need the dual line sending unit - that accurate ?
Brian
Brians1 is offline
Old November 15th, 2018, 05:51 PM
72 Olds CS
RetroRanger's Avatar
IDK about the correctness, but istill run my 350 fuel pump w no return w my 455. no vapor lock issues
RetroRanger is offline
Old November 15th, 2018, 06:02 PM
Brians1's Avatar
Good to know as I was wondering
Brians1 is offline
Old November 16th, 2018, 05:20 AM
I kept smelling gas at the rear of my 71 Cutlass, no puddles under car. I thought it was the rubber lines, but after removing tank I found the sender tube was no longer swedged or soldered or whatever causing the gas smell at rear of car. I checked on Rock Auto and found a new sending unit for about $30.00! Cheap! I ordered it and replaced along with all the hoses. I was surprised to find the sender for that cheap. I thought I would have to go to Fusick or similar. Maybe you'll want to check w/ Rock for your sender and maybe even a tank..
Greg Rogers is offline
Old November 16th, 2018, 05:30 AM
Brians1's Avatar
I'll look at rock auto this AM.
I decided since I will be putting in my 455 in Feb\March, Im going to go ahead and put the sending unit in that also has the 1/4 in return line, I'll plumb it to the engine bay and cap it off, this way I'm ready for the 455 transplant with the fuel pump that has the return line (working with a form member on a used 1/4 return line now vs buying new one). Im going to grab a few feet of 3/8, 5/16, and 1/4 fuel line and some clamps that way way when I swap in the new tank, I'll change those out as well. I still have the original vapor canister as well (have to check its condition).
I took a few pics underneath last night with my phone so I could make sure of my setup, here is a peak..
Brian
Brians1 is offline
Old November 16th, 2018, 06:10 AM
Brians1's Avatar
BTW - great call on Rock Auto - WAY cheaper than OPGI for the same tank and sending unit - almost 40% cheaper. Just purchased it
SPECTRA PREMIUM GM34R Fuel Tank $143.79
SPECTRA PREMIUM FG91D Fuel Sending Unit $33.79
Thanks - Brian
Brians1 is offline
Old November 16th, 2018, 08:36 AM
mrolds69's Avatar
I'm looking at that Spectra sender, and I see it's different than the sender they had available before. Did you install that unit, Greg? Does it work normally, like the needle at overfull when full and somewhat accurate? Before the float was different and the pipes at the top weren't bent right. That's what I had heard. Old unit looked like this...
Amazon Amazon
mrolds69 is offline
Bmoskal
September 19th, 2018 10:15 AM
my71olds
June 4th, 2018 01:23 PM
Bozang1
April 26th, 2015 05:38 AM
agtw31
August 20th, 2010 08:40 PM
MarkR
April 29th, 2010 12:32 PM
Quick Reply: 72 | Fuel Tank and Sending unit details
