Charcoal Cannister question
Old February 16th, 2010, 02:33 PM
1971 442 convert
1971 442 convert's Avatar
Does anyone know if the bottom piece for the charcoal cannister is available?
1971 442 convert is offline
Old February 16th, 2010, 05:11 PM
Lady72nRob71's Avatar
I have never seen anything like that...
Did it used to look like this?
This is the bracket that holds the canister.
I know they are not reproduced - used would be your best bet.
The canister itself and the bottom filter are all i know are available.
Lady72nRob71 is offline
Old February 16th, 2010, 05:36 PM
1971 442 convert
I am not sure maybe if so I am missing a few inches LOL
Old February 16th, 2010, 05:41 PM
Registered
Bluevista's Avatar
I was thinking the same thing Rob.
Those steel eating rats really got to that one if so.
Why does every bolt or nut you drop anywhere near that canister go right underneath it?
Bluevista is offline
Old February 16th, 2010, 07:48 PM
1971 442 convert
Well blue I might be better off with no holder then I can just pick up the darn thing to find my drooped parts ha ha.
Old February 17th, 2010, 02:58 AM
Registered
Bluevista's Avatar
One word... duct tape.
Hey Rob, it looks like that one in the pic is a little rust encusted and has a few holes in it?
Moisture must sit in-between the canister and the bracket.
I've never seen those reproduced either and the part number doesn't turn up anything at GM or Vparts.
Try posting in parts wanted, maybe John/2blu442 has one somewhere in his treasury-o-old-Olds parts.
Do it quick before Rob does.
Old February 17th, 2010, 05:21 AM
The way the canister fits in the holder, water is held between them very well also.
This was the worst rust I had on the car, after the lower front fenders and battery tray. The tray and canister holder were POR15'ed, so no more rust for them for a while...
After the battery and canister are installed, yo can't see them anyway.
1971 442 Convert , as bad as yours look, velcro (or DT) would be an alternative until you can get a usable steel piece. If you get one, POR15 it...
Old February 17th, 2010, 05:27 AM
Maybe you can get one of those charcoal canister holders out of a Chevy or Buick...
Olds64 is online now
Old February 17th, 2010, 05:28 AM
1971 442 convert
Thanks Rob and OLds 64
Old February 17th, 2010, 08:37 AM
Measure your canister and visit your local u-pull-it yard. Like Olds64 said, those cans were used in many different GM cars and trucks. You can even make your own mounting holes and since you cannot see the mounting when the can is installed, originality is not compromised too much.
According to Rockauto, the 71's 455 can is interchangable with:
BUICK(1972 - 1995)
CADILLAC(1971 - 1995)
CHEVROLET(1973 - 1995)
GMC(1974 - 1995)
ISUZU(1991 - 1994)
OLDSMOBILE(1971 - 1993)
PONTIAC(1971 - 1993)
Should be easy to find a holder!
Old February 17th, 2010, 08:48 AM
70 cutlass s's Avatar
I believe later years didn't use a holder like that. The inner fender is molded plastic and had place for the canister to set in, no bracket. If I'm remembering right.
70 cutlass s is offline
Old February 17th, 2010, 09:01 AM
Very true - I am sure you are right. To find a metal holder, look at the 70's vehicles of all GM brands.
I think my 86 Olds has a molded 'holder'...
Old February 17th, 2010, 09:22 AM
1971 442 convert
Thanks guys much appreciated
rhett838
July 24th, 2015 12:23 AM
The Bug Man
November 5th, 2013 06:14 AM
The Bug Man
March 19th, 2013 06:00 PM
Gary's 2 442-S
March 31st, 2010 04:19 AM
esisson
November 23rd, 2008 10:05 AM
Quick Reply: Charcoal Cannister question
