Gas tank and strap rubber mats
Old April 3rd, 2024, 06:28 AM
ajr2820's Avatar
How effective/necessary are the tank strap rubbers and rubber mat for the gas tank? Do they really work to keep down the squeaks and rubbing or is it just a gimmick? Getting ready ti install the tank and want to know if I should include that. Figuring on buying some 1/8" thick rubber sheets and cyt them to fit.
ajr2820 is offline
Old April 3rd, 2024, 06:59 AM
jaunty75's Avatar
Why would they be a gimmick? Why would GM or any manufacturer install parts that do not do anything?
Of course they work. Any place where two pieces of metal might rub together, such as between the gas tank and the straps that hold it in place or between the gas tank and the underside of the car are locations where noise and wear can occur. The rubber prevents both.
jaunty75 is offline
Old April 3rd, 2024, 08:08 AM
ajr2820's Avatar
Just asking because to my knowledge, they were not used on all vehicles....maybe I am wrong on that.
ajr2820 is offline
Old April 3rd, 2024, 09:41 AM
Bfg
Bfg's Avatar
There was not any installed in my 65 442.
Bfg is offline
Old April 4th, 2024, 08:00 AM
jaunty75's Avatar
I doubt they were used in every car. It is a quieting thing more than anything else, so I would think they're more likely to be in cars that emphasize their quiet ride, like full-size cars. People buying 442s were not typically concerned with a quiet ride. Leaving them off was a way to keep the cost down.
I will say that I have removed gas tanks in three cars, all full-size Oldsmobiles ('67 Delta 88, '73 Delta 88, and 1978 Toronado). I'm pretty sure, in all three cases, that it was the first time the tanks had been removed from the car, and none had rubber insulation between the straps and the tank or the tank and the underside of the trunk. Maybe it was included in some cars for other reasons? Better fitment?
jaunty75 is offline
Old April 4th, 2024, 09:45 AM
acavagnaro's Avatar
I can only speak for '69 Cutlass and 442's. There should be a large rubber type 'mat' between the tank and trunk floor. You can see corners of the material on an original car. No insulation between the tank straps and tank. I've never tested the noise quality of car without the large mat installed but it seems pretty foolish to drop a tank and not reinstall this relatively cheap insurance.
acavagnaro is offline
Old April 4th, 2024, 11:35 AM
rfpowerdude's Avatar
My 1970 Cutlass S had the mat on top and nothing on the straps, I am installing a new tank and I am putting rubber on top AND on the straps as I have an in tank fuel pump now. Hopefully it will help on transferred pump noise...
rfpowerdude is online now
Old April 4th, 2024, 12:58 PM
ourkid2000's Avatar
What are you using for the rubber on the straps? I'd like to do the same but I'm not sure what to use.
ourkid2000 is offline
Old April 4th, 2024, 01:03 PM
I bought 4 of these when I bought the tank and the pump and all of the mounting/install hardware.
https://www.summitracing.com/parts/TNK-SL24
A little high for what they are, but they are convenient.
Tuffnut
January 4th, 2024 01:35 PM
jensenracing77
August 28th, 2017 04:47 AM
Fabian Olalde
December 8th, 2016 05:39 AM
alburk
January 28th, 2016 09:43 AM
Quick Reply: Gas tank and strap rubber mats
