i got the car to run after 10 years sitting..
Old July 13th, 2011, 03:14 PM
fasteddi's Avatar
ok i got the olds 98 to fire up today...but i have a small problem first. what king of rodchester carb is on this car its a 1962 olds 98.. and second...the carb leaks alot on the front right side of it when your stand in front of the car...its leaking out a plunger or somethin....it has a rubber groomet arround it....what is this called so that i can figure out how to stop the leak... thanks for any help...
fasteddi is offline
Old July 13th, 2011, 03:41 PM
justinj's Avatar
Should be a Rochester 4GC.
My 4GC had the same problem - it's from the rubber boot getting too old and maybe exposure to ethanol in gas, etc. You can get a new carb kit at Napa and it should have the rubber plunger piece. Worth saving the rest of the kit and rebuilding the carb as well.
You won't have to remove too many screws to replace the boot itself.
justinj is offline
Old July 13th, 2011, 03:44 PM
justinj's Avatar
You can view the pages of the manual for that carb here:
http://www.oldcarmanualproject.com/m...eMan/index.htm
justinj is offline
Old July 13th, 2011, 03:58 PM
fasteddi's Avatar
thanks
thanks for the site and help.. can i just buy the boot... i have a kit for the carb already but its missing that boot... just my luck! what is the part that the boots for called?
fasteddi is offline
Old July 13th, 2011, 04:03 PM
fasteddi's Avatar
is it called the pump plunger boot
fasteddi is offline
Old July 13th, 2011, 04:06 PM
justinj's Avatar
Same thing happened to me and I had to buy another kit! The Napa kit had the boot inside and the one from Fusick didn't.
Officially called "Boot - Pump Plunger" here on this page:
http://www.tocmp.com/manuals/Carbs/R...G_0014_jpg.htm
justinj is offline
Old July 13th, 2011, 04:10 PM
fasteddi's Avatar
nevermind im jsut gonna buy another kit since there so cheep.. thanks alot for the help and info!!!!
fasteddi is offline
Old July 13th, 2011, 04:47 PM
chequenman's Avatar
Exclamation
What you're playing with is the accellerator pump which adjusts your fuel flow when stepping down on the Noisy pedal or some call it the Gas Pedal
chequenman is offline
Old July 13th, 2011, 04:48 PM
fasteddi's Avatar
napa??
was the kit from napa...who made the kit???? im having problems finding a kit for that carb... thanks
fasteddi is offline
hamco53
January 1st, 2015 07:22 PM
304forest
December 19th, 2014 02:28 AM
StickW31
September 28th, 2012 05:22 PM
mryoung4815
August 19th, 2011 11:51 AM
fasteddi
July 14th, 2011 11:16 AM
Quick Reply: i got the car to run after 10 years sitting..
