Power Steering Pump Selection - Rack and Pinion
Old March 26th, 2024, 02:42 PM
Oldscutty72's Avatar
Lightbulb Power Steering Pump Selection - Rack and Pinion
Afternoon All,
I am in the process of doing some major overhauls on my 72' cutlass supreme. I am looking to install the flaming river rack and pinion that recently fell into my lap. That part itself looks pretty straight forward. the issue I am trying to figure out is what aftermarket power steering pump will bolt up to a 350 rocket that has the reduced PSI a rack and pinion requires. Stock pump puts out roughly 1200 PSI while the rack likes 800-900 PSI. has anyone else done this conversion and setup a different type of power steering pump in the car without forking over the mega money flaming river wants for there pump?
any assistance would be much appreciated.
Thank you
Oldscutty72 is offline
Old March 26th, 2024, 06:28 PM
You should be able to simply change the pressure regulation valve in the outlet port of the stock pump.
joe_padavano is offline
Old March 27th, 2024, 09:59 AM
Thumbs up Solution
Thanks Joe, i didn't realize that was possible, i will look into finding that part. appreciate that!
Fazer
April 13th, 2019 08:35 AM
Stevec
April 28th, 2016 11:58 AM
JpMotorsports
August 26th, 2015 01:57 PM
1kool88
Brakes/Hydraulic Systems
October 22nd, 2014 03:49 PM
blakes7
May 3rd, 2014 09:58 PM
Quick Reply: Power Steering Pump Selection - Rack and Pinion
