pre-load on front wheel bearings
Old October 7th, 2013, 05:38 AM
Sid
Sid's Avatar
I am replacing the front wheel bearings on my 67 cutlass and can't find the spec on torque for the bearings? Thanks for any help.
SID
Sid is offline
Old October 7th, 2013, 06:43 AM
SID
This is something you do by feel. With the wheel spinning, tighten the nut until you feel drag to ensure the bearings are fully seated. Back off until loose then with the wheel spinning, tighten until you just start to feel drag. You may need to back off just slightly from the point to insert the cotter pin.
joe_padavano is online now
Old October 7th, 2013, 06:50 AM
x2 on Joe's procedure.
oldcutlass is offline
Old October 7th, 2013, 07:46 AM
oldspackrat's Avatar
X3 for sure.
oldspackrat is offline
junior supercar
Drivetrain/Differentials
27
October 30th, 2013 08:16 AM
oldzy
September 14th, 2010 05:40 AM
mp71conv
December 17th, 2008 11:03 PM
dantana
May 20th, 2008 12:19 PM
Andrew240
December 22nd, 2007 01:54 PM
Quick Reply: pre-load on front wheel bearings
