442 Power Driver's Seat Question?
Old April 9th, 2009, 02:02 PM
69442's Avatar
Does anyone know where I can buy driver's side power bucket seat parts for a '68-'72 442? Such as: the electic motors & cables. Thank you in advance!
69442 is offline
Old April 9th, 2009, 02:19 PM
68Tom's Avatar
Yikes. Not to discourage you, but good luck with that. I'm guessing you're going to have to have your seat motor rebuilt. From what I've read, it's not too difficult a job provided you find the right person.
As far as cables are concerned, place a wanted ad on 442.com. Also, you can try a few places I've had luck with such as Central Grade Auto (208-743-9505) and All American Classics. http://www.allamericanclassics.com/
I'm guessing the GM A-bodies used similar parts, cables and motors from 68-72. Someone might be able to chime in here on that, but you might find what you're looking for from some of the Chevelle parts houses.
68Tom is offline
Old April 9th, 2009, 04:20 PM
The 67-72 A-body seat tracks are the same.
joe_padavano is offline
Old April 10th, 2009, 03:08 AM
Yellowstatue's Avatar
Smile Electra Glide
The motor assembly from a bench seat car will work if it is a four-way...If your cable casings are intact then you could use the inner drives from the longer bench seat donor, shortened to length..
Yellowstatue is offline
Old April 10th, 2009, 05:28 AM
Yes. Most people do not realize this.
Old April 10th, 2009, 04:16 PM
68conv455's Avatar
I'm re-covering the front buckets for my 68 cutlass S. The drivers seat is power and I've taken the power assembly off to do the work. I've looked on E-bay because I'm curious about the value of the power seat assembly. I've seen at least two different sellers in the past few weeks selling the assembly. (It bolts in where the seat tracks normally go). Haven't seen them as catalogue items new. The assembly should look like this.
68conv455 is offline
Old April 11th, 2009, 02:45 PM
Registered
Bluevista's Avatar
USA Parts Supply has the cables and rebuilt motors, some other parts.
http://www.usapartssupply.com/default.htm
Bluevista is offline
oldspackrat
September 29th, 2014 01:35 PM
cdaolds
October 29th, 2013 04:21 PM
f-85
June 11th, 2012 12:30 PM
jensenracing77
April 5th, 2011 08:44 PM
KZ442
April 10th, 2009 03:16 AM
Quick Reply: 442 Power Driver's Seat Question?
