CONVERTING POWER BENCH SEAT TO POWER BUCKET 442
Old March 14th, 2009, 08:09 AM
KZ442's Avatar
Hello,
I am in the process of converting my power bench seat 1972 442 to a power drivers bucket and a manual passenger bucket seat. I been told alot of different ways it should work like the track should bolt in the outer holes and just weld in a inner floor brackets. When I bolt the power track to the outer holes its to far over towrds the door. I then bought a set a of power seat floor brackets but I don't know if I have to cut out the olds ones? If anybody has a template, measurments or any ideas I would greatly appreciate before I start welding our cutting out old brackets. The only one question is a manual bench seat mounting differnent then a power bench?
Thanks,
KZ442 is offline
Old March 14th, 2009, 09:24 AM
2blu442's Avatar
Power Bench to Buckets
Please add the year of your car to the posting. I pulled a power bench seat from a 1971 Cutlass years ago. There was something different in the mounting, I believe the power had an extra stud on the floor at the rear bracket. As far as location I'm not sure. I should have floorboard portions from a 1968 with power buckets, I'll see if I can locate those to photograph if that would help. John
2blu442 is online now
Old March 14th, 2009, 12:02 PM
KZ442's Avatar
Sorry,
It's a 1972. Thank You
KZ442 is offline
Old March 14th, 2009, 02:09 PM
2blu442's Avatar
Here's some photos and measurements for a 1968 power bucket. I don't know if the 1972 used something different. This is only the floorboard portion right next to the door. I'm posting a couple photos but I've taken several more you can view on my photobucket site, the link is: http://s90.photobucket.com/albums/k257/2blu442/
Overview of the welded on bracket
Measurement from center of stud to center of stud
Front bolt, measurement from edge of floorpan to bolt
Rear bolt, measurement from edge of floorpan to bolt
Old March 15th, 2009, 08:27 AM
KZ442's Avatar
Thank you, I appreciate the info. I think 68 thru 72 are the same but I will use the measurements and see how the seat lines up to the steering wheel. Thanks Again
KZ442
KZ442 is offline
Old April 10th, 2009, 03:16 AM
Yellowstatue's Avatar
Smile Mounts
I used a pwr bench seat bracket to convert a manual bucket to pwr in a '68 442...and added a stud to the existing inner bracket where the unused hole is... and padded over the unused stud..the donor was out of a '69 Vista...
Yellowstatue is offline
RAMBOW
July 26th, 2016 08:05 AM
69442murph
July 9th, 2014 04:55 AM
Ddbord
June 19th, 2012 02:08 PM
Jonb442
January 11th, 2010 12:46 PM
sleeton
November 9th, 2009 01:50 PM
Quick Reply: CONVERTING POWER BENCH SEAT TO POWER BUCKET 442
