Column Shift Lever
Don’t want to bum you out, but don’t pass on a complete column that has the parts you want.
Sellers often have strong ideas about how granular they want to go with selling individual parts.
Chris
Chris
I just restored a couple of tilt & tele big car columns which share almost nothing with your A-Body column, but I can confirm that they’re very robust and don’t really wear out. The mechanical parts were very well made and the trim can be restored without too many troubles.
I got mine in good shape, but am just not a good painter, so I farmed out the repaint of the trim pieces (semi-gloss black or so) to a local body shop, It will be fun to see what they come back with. I’m sure it will be better than my rattle-can resto effort.
Cheers
Chris
Cheers
Chris
Hey Chris, (or anybody) Any luck? I have a clean 65' 98 LS and same problem with a faded dice cube for a ****. ISO in any leads~ Thanks
At least for the 65-66 big cars, I can confirm that the Tilt lever end and Turn Signal lever ends swap.
I’m 99% sure the column shift lever end will _not_ swap with either of the other two. There are 2 points of mismatch I believe:
1) outside diameter of the lever shaft
2) length of the shaft splines.
I can’t comment with any authority whatsoever on the Cutlass/442/VistaCruisers. I just don’t know much about A-bodies…
Chris
Chris
I usually buy parts from Original Parts Group but I also buy from Fusick and eBay.
That's all I have used. OPG for generics, Fusick limited, and $ Ebay seems to come through if you're diligent. Swap meet season is coming soon.Fortunately I'm pretty complete (but are you ever?) on my 98 lux. A far cry from all my Chevy experiences with everything readily available.. But now I'm into Olds and now looking for more to buy. How did this happen? lol
Toms cutlass
November 14th, 2021 08:10 AM
Rocketbrian
October 2nd, 2013 10:18 AM
