425
Hey guys looking for cam advice hydro tapper. The motor is in the shop. Machine work nearly finished. I’m looking for street car. Not overly concerned with track time or Hp. I want it to pull hard and have a very roudy idle.
425 toro block. 30 over
DSS pistons 10-1
Johnson .921 lifters
Edelbrock heads performer intake
Muncie 4 speed
342 rear.
based solely on internet research these are my top choices. Are these good choices . Better options ?
also I see comp adversities for extra money nitrate hardening. Worth it? Do other
Manufactures offer that? Not excited about the 8-10 week wait for that service.
all flat tapper recommendations welcome. Please provide explanation’s I’m learning.
Isky mega 280. 232 @50 280 516 108 lsa
comp thump. 234/249 286/304 500 486 lift 107 lsa
DSS pistons 10-1
Muncie 4 speed
342 rear.
DSS pistons 10-1
Muncie 4 speed
342 rear.
DSS pistons 10-1
Muncie 4 speed
342 rear.
If you have power brakes, you might need to add Hydroboost for vacuum.
What Muncie do you have ? M20 or M21 ?
Is your block 45 degrees lifter angle or 39 degrees ?
What carburetor are you going to use ?
Whats been done to the heads ? How many CC's ?
Do you mean Nitride hardening ?
How did you arrive at the cams you listed? What criteria did you use ?
M20
39
750 do also have a Holley sniper ( heard they don’t like the tigh lsa)
heads are standard 77 with a valve job
Yup nitride
Do you have experience w a can of similar dimensions to provide feedback?
criteria is roudy idle/pulls hard/ good for street use.
I took a w34 cam out of it. It was a turd. Idled like a Cadillac. No pull after 3000 rpm. Using that information aswell.
How did you arrive at the cams you listed? What criteria did you use ?[/QUOTE]
39
Yup nitride
67cutlass425
April 27th, 2020 07:14 PM
