'65 F-85 Club Coupe
Old May 27th, 2015, 02:58 PM
Rallye469's Avatar
'65 F-85 Club Coupe
Well I just dragged my '65 F-85 down from NY to FL.
I bought this car in '08 and haven't touched it since...just sat in my garage collecting dust.
It's a Deluxe V8, but the engine is long gone.
The cool thing about it is the very empty data plate:
-02C(3rd week February)
-LAN
-903(blue clothe bench seat)
-D-D(lucerne mist)
After that, it is completely blank.
It's a stripper and that's the way I'll keep it.
Planning on making it a simple cruiser with original steelies.
I'll post more picts when I get them.
-Pete
Rallye469 is offline
Old May 27th, 2015, 03:15 PM
Awesome shape
oldcutlass is online now
stan 65 cutlass's Avatar
very cool, no pitted side chrome to replace. looks like a chrome rear panel? or is it bars and an emblem? does it have rocker chrome? auto or manual shift?
stan 65 cutlass is offline
Old May 27th, 2015, 04:21 PM
Justin
oldstata's Avatar
Very nice start, looks like bars and emblem in the rear, maybe a better pic is in order. Also looks like no window stainless on the doors painter quarter trim ?
oldstata is offline
Old May 27th, 2015, 04:29 PM
therobski's Avatar
Nice start!! look up my thread in this section " update progress on 64 post" if you do 1/2 of what I did you need your head examined!! Good luck if I can help let me know!
therobski is offline
Old May 27th, 2015, 04:32 PM
Justin
oldstata's Avatar
Lmao
oldstata is offline
Old May 27th, 2015, 09:38 PM
Rallye469's Avatar
It's an automatic on the column.
No rocker chrome or post chrome.
The rear fascia has the bars and the hood had the shorty spear, but that's gone now. Some one welded up the holes then cut a huge hole in it for a scoop.
Kind of a waste if you ask me.
I got this from a guy who gutted it and was about to throw a BBC in it to race it.
Saved in a nick of time.
-pete
Old May 28th, 2015, 07:13 AM
Rallye469's Avatar
A few miscellaneous picts, plus the data tag and the rear fascia.
-Pete
Old May 28th, 2015, 12:45 PM
Justin
oldstata's Avatar
Surprised it doesn't have reverse light delete. Also the good doesn't look bad from that angle
oldstata is offline
Old May 28th, 2015, 01:25 PM
TK-65's Avatar
Has three options I can see, back up lamps, automatic transmission and two speed wiper/washers.
TK-65 is offline
Old May 28th, 2015, 02:50 PM
Rallye469's Avatar
Would those options be listed on the data tag normally?
And one other question...What's the "S" mean stamped above "LAN"?
I've seen A, B, C, S or just blank on other plates?
-Pete
Old May 28th, 2015, 08:04 PM
therobski's Avatar
Bro, again thats a nice car to start on and a "post car" at that, any plans? Hood is not an issue to replace.
Old May 29th, 2015, 03:45 AM
TK-65's Avatar
-Pete
No. If the auto was on the floor, it would be noted on the cowl tag because a hole was required. Anything that's not body related like back up lights, radio, clock, power brakes, power steering, wiper type would not be on the cowl tag.
TK-65 is offline
Old September 11th, 2019, 07:31 PM
Rallye469's Avatar
Started this thread awhile ago.
But I’ve really wanted to stockpile photos and start collecting parts for resto.
the urge to get working on this is getting crazy
-pete
Old September 11th, 2019, 07:32 PM
Rallye469's Avatar
Nice “loaded” data plate.
Old September 12th, 2019, 11:11 AM
love it !!!!!!!!!!!!!
Old December 21st, 2019, 12:38 PM
64Rocket's Avatar
any updates ?
Gene
64Rocket is offline
Old May 7th, 2020, 11:46 AM
Rallye469's Avatar
Well...haven’t done much but I’m about to. Lack of space has always prevented this project but that’s changing.
I just bought a home with a 22x25 garage with enough room for the F-85.
I’m currently fixing up the garage so I should have the car home in 2 weeks.
But for now, I brought the engine home and will start prepping it.
It’s a 70 455 that seems to be in terrific shape. Although the top is painted corporate blue, nothing seems out of place. Original metallic blue is all over everything below the heads.
Thoughts on these pictures?
Old May 7th, 2020, 11:59 AM
therobski's Avatar
Great let the sweat begin!!! Again that's a nice example to start with..Ill be watching your build...
Old May 7th, 2020, 12:16 PM
64Rocket's Avatar
Since it is a two barrel carb it should be a low compression engine.
I'm doing the exact same engine and it has 32cc cup pistons. I cut .025 off the block and .025 off the heads and will be barely 8.8 compression. so i'm taking another .015 to up it a little more.
Gene
64Rocket is offline
Old May 7th, 2020, 12:26 PM
dc2x4drvr's Avatar
Nice looking coupe, what are your plans for the motor?
dc2x4drvr is offline
Old May 7th, 2020, 01:01 PM
Rallye469's Avatar
Gene, I thought the ‘70 was 9:1 to start with?
Dc2xdrvr...this is just a starter engine.
First, I’ll just change the timing chain and the oil pump, paint it and slap this on the top with HEI and headers. Pretty simple just to get an engine in.
But then....I may take the 496 and OD trans out of my Rallye and drop that in to this car. Then build a new rocket block 590 for the Rallye.
Old May 7th, 2020, 02:52 PM
I had toyed with putting one of those hood scoops on my 67 to run a high-rise manifold, just could not bring myself to cut the flat hood. Just following along on your build.
Old May 7th, 2020, 03:09 PM
oldsmoboogie's Avatar
Very cool, looking forward to your progress.
oldsmoboogie is offline
Old May 7th, 2020, 07:04 PM
64Rocket's Avatar
In my mind the offy is ok. I think the Edelbrock O4B is a great street manifold. The Torker is very good, some say not that great for the street, but is did great for me. I drag race a 64 Cutlass,back in the mid 80's, with a 425 that had the offy intake. I went to a 455 with the offy, ran 12.50's, change to a torker, ran low 12's. 12;15, 12;20 all day.
But the O4B did real good on the street.
Gene
64Rocket is offline
Old May 8th, 2020, 03:34 AM
Rallye469's Avatar
Gene, I have no doubts that this manifold isn’t the best performance wise. But I’ve always thought it was the best looking vintage manifold out there...plus the matching valve covers. It’s a lot more for show than go.
When it comes to performance I have the 70 to play with. This ones just for looks!
-pete
Old May 12th, 2020, 02:04 PM
Rallye469's Avatar
Any idea which seats came with my car originally?
I got both sets when I bought it which was weird because he wasn't an Olds guy and had no parts car.
thanks'
-peter
Old May 17th, 2020, 02:03 PM
Rallye469's Avatar
Just dragged her home from storage, and then her first bath in years. Now I get to begin!
Old May 17th, 2020, 05:34 PM
Gerald Nickels's Avatar
That 65 is way lighter than the 70. Like 400 lbs. When installing the 455 engine and 400 trans move the cross member back about 4" for the trans. I would run a 350 convertor on street. And about 3.42 rear gears 12 or 10 bolt cover. You still have to find a stock hood.
Gerald
Gerald Nickels is offline
Old May 17th, 2020, 06:52 PM
64Rocket's Avatar
I like the 3:23’s for the street.
Gene
64Rocket is offline
Old May 17th, 2020, 07:34 PM
  #31
Rallye469's Avatar
Gerald
& 64 Rocket
I think I will be removing my TH400 and Gear Vendors OD from the 70 and putting it in this one...
That should allow my to run a shorter gear...3.73’s maybe. I have a 12bolt lined up for it already.
As for the hood, I scored a nice ‘65 unit a few months back...just need to weld up the extra holes as I’ll only need a few for the short hood spear!
Old May 18th, 2020, 06:47 AM
  #32
therobski's Avatar
Wow what a NICE F-85 to start with! I think the 64-65 Base F-85's weight in around 3,085 lbs. light indeed. A lot of guys have seen my build 64 F-85 build in the past. Car was built around to handle a ton of torque and HP. Right now running a stock 67 400E, highly modified 220-4R and a Moser 9inch with a 3:50 gear. Another engine down the road or with today's parts availability could build a pretty awesome 400E. Keep us posted on your "baby blue" Love that car...
Old May 31st, 2020, 02:03 PM
  #33
Rallye469's Avatar
Nice little score today...wait...is it a score when it’s free?
Old June 8th, 2020, 09:07 PM
  #34
Rallye469's Avatar
Well, I’m 2 days into the tear down. I’ve been tagging and bagging parts and organizing what I have.
And noting parts I need.
-peter
Old June 9th, 2020, 09:38 AM
  #35
64Rocket's Avatar
65 A body
Is this car going to be street car ?
looks to be a pretty nice paint on the car.
good job , staying organized .
keep up the good work, keep us up to date.
Gene
64Rocket is offline
Old June 10th, 2020, 12:16 PM
  #36
1965Oldsmobile's Avatar
Peter, do you happen to know what year those dog dishes (in Post #33), are from? Nice car by the way, it looks like a great starting point, seems pretty solid. Thanks, Doug
1965Oldsmobile is offline
Old June 10th, 2020, 01:09 PM
  #37
jcdynamic88's Avatar
those caps are mid 70s
jcdynamic88 is offline
Old June 10th, 2020, 01:34 PM
  #38
jcdynamic88;1256307]those caps are mid 70s
jcdynamic88, thanks for the info! Doug
Old July 16th, 2020, 05:25 AM
  #39
Rallye469's Avatar
A few more disassembly pictures. It’s getting close to taking the body off. Just need to remove the rear bumper and emergency brake cables.
I also put in a 12 bolt rear that had been narrowed 2”. It will make getting the wheels and tires I want on it a bit easier I think.
Old July 16th, 2020, 05:35 AM
  #40
Rallye469's Avatar
Does anyone know who made these tail light cross bars? A while back someone made a bunch of these out of aluminum and chromed them. I picked up a set when I purchased these freshly rechromed bumpers and tail light buckets! Score!
Quick Reply: '65 F-85 Club Coupe
