Asylum Men Coming for the Maniac! Another 67 442
#46
It is a Sport Coupe referred as a post car because there is a solid divider (post) between the door glass and the quarter glass. The non post cars have a large opening when door glass and quarter glass is lowered.
#47
Stolen from another thread (Joe) on our site there are additional deltas which separate the posts from non-posts:
...in Olds-speak, a Sport Coupe IS a post coupe. Holiday Coupe = hardtop. Second, as others have noted, there are internal reinforcements that the hardtop has to replace the posts. The window tracks and regulators are different. The glass is different. The vent windows are different. The roof rails and weatherstripping is different. The interior upholstery is different.
#48
I see- I just googled "88 Holiday coupe" and I see what you mean. The 88 Holiday coupe has no post. I imagine there's F85's and Cutlass models similarly with no post- but not yours. Thanks!
#50
#53
#55
#56
wow ! Lol I’m keeping my mouth shut absolutely lol rock on joe and happy new year thanks for the laughs! Needed them today
Last edited by Eddie Hansen; January 3rd, 2024 at 10:25 AM. Reason: Spelling ( as usual lol)
#57
A few observations, while under the car continuing with the oil pan removal I see there is no undercoating on floor pans or frame, I thought undercoat was standard. I drained the oil to find about 2-3 quarts extra in the stock oil pan. I removed the starter to find one bolt not original and a stack of washers under the bolt head. I removed the Z bar and see a ball stud on the frame side with a much longer shaft than what I see on the 67 stick cars. This was causing the sharp angle of the pedal rod exiting the firewall however the fork push rod was in line for a straight push on the fork. The fork push rod is slightly bent. I also saw a metal plate bolted under the crossmember at trans mount bolts. I removed it to find molested trans mounting bolt holes. Seems the wrong trans mount was used and the crossmember molested to get the bolts to work. There is a heat riser valve in the driver's side exhaust manifold but the spring tension is so weak to close it is probably just flapping open and closed, it will be removed. There was no spring for the clutch fork. There was the standard bracket/support bolted to the hole in the side of the starter and engine block typically used on auto trans cars. Will get some pictures soon, engine is ready to be raised for oil pan removal.
#59
I thought I could jack up the engine high enough to drop the oil pan but seems there is not enough clearance at the firewall and accelerator linkage. I already pulled the distributer and exhaust manifolds. May as well just pull the engine and trans. This will give me a look at the clutch also and a chance to clean up engine bay as well. The oil pan did drop enough for me to look at the rods and crank....Hmmm seems someone thought they were building a race engine and had the side seams on the connecting rods ground smooth, no evidence though of any shot peening. Also the edges of the crank were taken down with a grinder. So more mystery there is here. All the extra oil in the pan was due to the dipstick tube being upside down and not even extending into the oil pan. Pictures soon.
#60
3 speed trans is out, tried extracting engine with the little Harbor Freight crane. Its not long enough with the front end together so need to set up the big one. Here are a couple of pictures that have me scratching my head. You can see the side slotted holes in the crossmember and the ball stud in the z bar appears to have been welded on and made longer. it is for sure longer than any I have seen before. And as mentioned before the thru the firewall clutch rod exited on a angle to the right. So it appears something went on in the past but the reason I cannot think of.
#64
Life keeps getting in the way of the project but I was able to go thru the carb. The little cam that raises the secondary metering rods was missing. I replaced that along with a very dirty fuel filter. Nothing else out of the ordinary was found. With Carlisle coming soon I plan on bringing the trans to Ed Hartnett just to go thru and make sure things are right. I am also going to get a Yukon posi unit for the O 12 bolt, 28 spline rear. The 323 gears will remain.
#65
So what better way to spend Easter, got the 400 out and mounted to my new HBF engine stand. A buddy helped and as expected the crank was hitting the oil pan, I dont think it wore through. I hammered out the dent and after cleaning and paint it will go back on. The rest of the engine needs a bit of degreasing and paint as well. Am glad to have found the source of the engine noise!
#66
Got busy with engine paint, and installed the intake manifold. I looked into new springs front and back. Am going with Detroit Eaton as soon as I get 800 bucks I dont need! Before the engine goes back in I want to remove the hood and windshield. Its so much easier repairing the channel there if needed without an engine there. If all is good at least a new seal for the winshield will be in place.
#68
#70
