Posi Traction??
Old May 22nd, 2013, 09:32 AM
travisbeamon's Avatar
Posi Traction??
How does posi traction increase performance exactly? I'm debating on having it installed in my 72 Cutlass while it's at the shop and just want a little more detain before I give the go ahead. I'm looking to get the best power performance out of my car as possible...
travisbeamon is offline
Old May 22nd, 2013, 09:52 AM
72 Olds CS
RetroRanger's Avatar
No performance increase per say, posi will just allow both wheels to have power to them VS an open differential which only powers the wheel w the least resistance.
RetroRanger is offline
Old May 22nd, 2013, 09:55 AM
Mr. Johnson
rjohnson442's Avatar
you'll have two tires giving you traction instead of one. Depending on the unit and the way the posi is set up you can get a huge increase in performance if set up correctly. they can turn you knuckles white in the rain though when it decides to apply more power. If you plan on going to the track a lot I'd go with a posi. Mines fully locked and it binds up more then I want it to in tight corners on small roads. I wish I went with a posi in the long run. maybe next year
rjohnson442 is offline
Old May 22nd, 2013, 11:00 AM
hookem horns's Avatar
Posi (Olds marketed it as anti-spin) does not add performance per-se, but helps keep both wheels engaged so you do not have the one wheel "sit and spin" common with open diffs. Assume you would also get a lower gear ratio (higher number) than stock along with the posi which definitely helps off the line performance. Trade off for the added fun is higher rpms and thus lower mpg on the highway. A 3:42 will spin around 3000 rpms at 65-70mph unless you have a modern OD transmission.
hookem horns is offline
travisbeamon
Drivetrain/Differentials
November 29th, 2012 07:12 PM
coppercutlass
Suspension & Handling
July 27th, 2011 05:56 PM
Redog
May 30th, 2008 02:45 PM
Redog
May 13th, 2008 07:41 AM
Newkid8
March 11th, 2008 07:52 PM
Quick Reply: Posi Traction??
