Hey all. Looking for some advice.
Old April 2nd, 2015, 07:52 PM
daspin's Avatar
I just bought a 1969 cutlass supreme covertible. I had a hardtop when I was 19 but rolled her racing as a dumb teen. I'm 42 now and slowed down. Finally bought my baby again. She's in great shape and was fully restored 10 years ago but as can be expected has a few issues I would like to resolve now.
1. The windows and convertible top do not line up well. Windows have like 1" gaps when putting them up as the top stops them from going all the way up. Can someone point me in right direction as to what I should be looking for?
2. The radio has major static when the car is running. Fine when engine is off. I heard something about this before but can't remember the cause.
She has some other issues but I think I can figure those out. Wipers not working. Driver door sagging at hinge. Power antenna not working.
The biggest issue for me is the lining up of the windows and covertible top. I can post photos or a YouTube vid tomorrow if someone has some advice.
Thanks all!!
daspin is offline
Old April 2nd, 2015, 08:03 PM
Welcome to the site, pictures of the window gap will help. We also wouldn't mind seeing pics of the whole car. The radio issue can be a missing capacitor on the coil positive if it still has points. Can also be related to your antenna problem or a bad filter in the radio power supply.
oldcutlass is offline
Old April 2nd, 2015, 08:54 PM
daspin's Avatar
Thanks for the reply. I'll take some pics tomorrow and post so you guys can get a better understanding of the issue.
daspin is offline
Old April 3rd, 2015, 07:58 AM
daspin's Avatar
Here is a video of the problem
daspin is offline
Old April 3rd, 2015, 08:44 AM
Definitely out of adjustment. I think this may be close to what you have.
Old April 3rd, 2015, 09:14 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Your top and all 4 windows need attention. First the top needs to be adjusted properly, yours looks like its sagging. Take it to a reputable auto upholstery shop that does vets tops if you dont have the nohow. They do it all day and should be able to get it right for you. The top mechanism may need some parts too?
Then fix the door hinges. The doors need to be lined up nice before window adjustment.
Then go at the windows. Pull the seats and door panels out of the car it will make life much easier and you wont need to see a chiropractor when finished. Sit inside of the car and start adjusting one at a time. Mark the original locations of all the adjustment points so you can at least get back there if needed. Adjust the door glass to fit nice then go at the quarter windows. Clean and lube the window tracks replace any worn rollers etc...Also clean all electrical connections to the power window motors and be real sure the grounds are all clean and tight. I also recommend getting the manuals for the car. Chassis, Fisher, Assembly and Chilton or Motors repair manuals.
droldsmorland is offline
Old April 3rd, 2015, 09:38 AM
daspin's Avatar
Thanks guys. I messed around with some more and it seems as if the biggest culprit is the main windows coming up tilted. If I force them up straight with my hand it seems to close and line up pretty good. I Think I'll take the advice and take it to someone who knows better than me. Lol
daspin is offline
Old April 6th, 2015, 06:06 AM
Dont forget to freshen up the door hinges first before making any adjustments. Then adjust the top.... then the windows. If you dont do it in this order you'll chase your tail. Consider replacing any worn rotted weather seals before adjusting too... to include the top rail weather strips.
Old April 6th, 2015, 06:48 AM
daspin's Avatar
The doors seem to open and close nicely. The drivers side has a bit of sag to it but passenger side close perfectly. Are you suggesting I replace the entire hinge assembly? Or just the pins?
daspin is offline
Old April 6th, 2015, 07:13 AM
72 Olds CS
RetroRanger's Avatar
Just the pins and bushings need replacement, unless there's something wrong w the hinges Typically original GM parts are going to be better than any reproduction part.
After your door hinges are set, you may also need to adjust the fr door glass as well, it has similar adjustment bolts and slots as the rear glass. Your windows are also binding or the motors need refreshing the windows shouldn't be that slow.
RetroRanger is offline
Old April 6th, 2015, 08:16 AM
daspin's Avatar
Thanks guys! Any idea where to find original GM parts? I only know of opgi for reproduction parts and shipping is a fortune to ship to Canada.
daspin is offline
Old April 6th, 2015, 08:24 AM
The bushing and pin kits are widely available. Check with your local NAPA, United, Federated etc...Stay away from big box as they will likely be offshore junk. You may be able to find at a GM dealership too? Year One, Fusick etc...has GM parts mail order. These two companies also offer complete hinge assemblies. Just paint n go.
Old April 7th, 2015, 08:44 AM
wait.... what....
oldzzy's Avatar
Where do you live in Canada?
oldzzy is offline
Old May 11th, 2015, 04:37 PM
daspin's Avatar
Didn't see this post. I'm in Port Perry, Ontario
daspin is offline
1970blueolds442
May 14th, 2014 12:26 PM
Mikesta
March 27th, 2013 06:51 PM
ottospeed61
December 9th, 2010 06:43 PM
olds_man_75455
November 29th, 2009 07:19 PM
FiveSeven
March 16th, 2009 11:52 AM
Quick Reply: Hey all. Looking for some advice.
