Slim Jim Transmission
Old December 26th, 2023, 05:51 PM
Colorado Starfire's Avatar
Got a 1963 Starfire with slim Jim Trans. It is getting weak, and no one here wants to touch it. Looked into a newer trans. upgrade, but it requires too much cutting and fab work. Looking for any suggestions, Thanks
Colorado Starfire is offline
Old December 26th, 2023, 06:44 PM
Where in Colorado are you? Who have you asked to work on it?
no1oldsfan is offline
Old December 26th, 2023, 07:04 PM
Phantom Phixer
Charlie Jones's Avatar
Read this thread.
My New TH400 Compared To Slim Jim - ClassicOldsmobile.com
Charlie Jones is offline
Old December 26th, 2023, 08:36 PM
Boy it is hard to log in here.
Old December 26th, 2023, 08:43 PM
So where in Colorado are you? Who have you asked to work on it?
Old December 27th, 2023, 03:01 AM
Thanks for posting the link Charlie. It seems that Ross Racing had some poor customer service that was unresolved in that thread. If you pay for work like that make sure you use a credit card.
Olds64 is online now
Old December 27th, 2023, 07:20 AM
Colo Springs
I am located in Colorado Springs and have tried local rest shops as well as transmission shops, local and franchise.
Old December 27th, 2023, 10:51 AM
Fonz's Avatar
I "used to be" a Fan of the slim jim, (you're right, no one wants to touch them. ) BETTER, Use a 700R, Same lower 1st gear And has a OVERDRIVE, and is very easy to rebuild ! I put them in everything now..
Fonz is offline
Old December 27th, 2023, 10:57 AM
Old December 27th, 2023, 10:59 AM
Thanks Fonz, do you know what kind of mods are required for 1963 Starfire ragtop? It has factory center cousole with tach.
Old December 27th, 2023, 11:06 AM
Fonz's Avatar
not familiar with a 63 starfire.. from what I remember about a slimjim, they are smaller around than most auto trans,.so the trans tunnel may need to be altered (Maybe not, because in 64 they changed from slimjim to 400 trans) only thing I'm" SURE of", A 700R IS A BETTER TRANS ! AND WILL WORK WELL IN A HEAVY CAR.
Fonz is offline
Old December 27th, 2023, 12:37 PM
I've mentioned it before on our site, the Slim Jim Rotohydramatic is NOT a good transmission. Unless you're doing a concours restoration on your Starfire, you should make plans to replace it. The TH400 is bulletproof. Probably can't go wrong with a 700R4 or 2004R either since you're having the case modified anyways.
Old December 27th, 2023, 12:46 PM
X2. Basically isn't that just a drop in? I don't know a 63 so forgive me. If so that is what I would do.
Old December 27th, 2023, 01:35 PM
Rocket Renegade!
Nope, what I recall from other threads on here is that tunnel/floorpan mods are required.
If you haven't already, you might inquire with these guys. They might be able to give you some ideas with regard to sorting out your Slim Jim:
www.fatsco.net
BangScreech4-4-2 is offline
Old December 27th, 2023, 03:31 PM
I will see what I can find out also for you. My Brother lives down there. He is also a gear head. He is having serious health issues right now so I may not get a quick answer. I will see what I can find out.
Old December 27th, 2023, 04:36 PM
Here's another thread on a Slim Jim conversion. Apparently the user in the thread Charlie posted; ripper27, finally got his Ross Racing conversion done.
https://classicoldsmobile.com/forums...ebuild-156406/
Old December 27th, 2023, 05:51 PM
OLDSter Ralph's Avatar
not familiar with a 63 starfire.. from what I remember about a slimjim, they are smaller around than most auto trans,.so the trans tunnel may need to be altered (Maybe not, because in 64 they changed from slimjim to 400 trans) only thing I'm" SURE of", IT'S A BETTER TRANS ! AND WILL WORK WELL IN A HEAVY CAR.
I believe you are wrong. The "switch pitch" 400 came in 1965 B-body cars with 425. You should have had a Slim Jim in the 64 Starfire with the 394 engine. 1964 was the last year for the 394 and Slim Jim.
OLDSter Ralph is offline
Old December 27th, 2023, 08:53 PM
Fonz's Avatar
Been wrong before, what i "tried to say" was, the 700r is much better than a slim jim
Fonz is offline
Old December 27th, 2023, 08:54 PM
So does a 700r fit better? Great transmission if so.
Old December 28th, 2023, 03:32 AM
I think the user in the threads that Charlie and I posted; ripper27, actually used a TH350 in his Ross Racing conversion. It fit better than a TH400 and is still a much better transmission than the Slim Jim Rotohydramatic.
Dutchop18
June 10th, 2021 10:15 AM
dennis_30281
June 17th, 2018 07:08 PM
Oldpac62
November 9th, 2017 03:46 PM
metalhead
February 21st, 2012 07:44 PM
gmacolton
April 29th, 2010 12:53 PM
Quick Reply: Slim Jim Transmission
