72 Olds 98 Best Improvements made so far
Old October 30th, 2023, 09:03 AM
Nutmeg 72 Olds 98's Avatar
Since getting the 98 out of storage in the spring of 2022:
We replaced the cracked exhaust manifolds using the reproduction 442 Dual Exhaust Manifolds (Fusick Automotive or Thornton) with fresh gaskets for the 455. The stock items were a weird contraption routing drivers side into the passenger manifold and then exhausting the whole thing into one 2 1/2" pipe with one giant muffler and resonator. The thing was like having a dinosaur breathing thru a straw. The fresh 2 1/2" pipes with a crossover pipe, flowmasters and no resonators woke up the engine, its very happy now and the bonus is noticeably better gas mileage while sounding better doing it, courtesy of the genius skill of Hot Rod Scott's in Toronto.
The next improvement was the HEI Pertronix FlameThrower distributor with fresh wires and spark plugs. Again smother running and more consistent power. All of it looks factory stock and discreet.
Next was the internally regulated alternator when the voltage regulator gave up. Casualty of that event was replacing the bulbs and headlights with LED's so I can see in the dark now. The regular T3's were so yellow I have no idea how anyone could see when they were new in the dark. Now they are bright like a UFO... there is light.
The gas tank was removed, cleaned sealed inside with a new sending unit from a large tank 72 impala. The 98 Tank sender unit is a one off strange contraption like a cylinder that seized and didn't work. The filter sock was disgusting. A replacement is non existent. There is a company that rebuilds them, ( will try that ) but the tank is unavailable new. The 73-76 tanks are available from Spectra but have the newer style sending unit hump the 71 and 72 dont have and therefore wont fit without modifying the trunk floor... not an option.
The engine compartment needs some cosmetic detailing now with fresh stickers and some touch up paint next spring.
The A/C was tested and holds pressure so it will be recharged with R12 in the spring. What a machine. All those relays and wires still work.
S&M had the seat upholstery for the front couch. Next year it will be redone. That leaves some paint correction and thats about it...
But as we all know a project is never really done is it.
Check out the pix...
BTW dryer sheets for the mice really do work keeping those buggers away.
Engine Compartment
Cleaner
Tank Sending Unit
Pertronix HEI Flamethrower Distributor
Eugene
Nutmeg 72 Olds 98 is offline
Old October 30th, 2023, 09:32 AM
Eugene, it's good to hear that the W & Z manifolds with dual exhaust woke up your 98. I got a set of those manifolds from a member on our site and had them on my 71 98 for a time. I ended up installing headers. One of the MANY stupid things I've done to my Oldsmobile.
FWIW, keep a spare HEI module in your glove box in case the one in your distributor gives you a no HOT run condition. This has happened to me multiple times in my 71. The only way around it is to get a good quality AC Delco module.
Here's a good thread with additional links on replacing the fuel sending unit in your tank.
https://classicoldsmobile.com/forums...2-98-a-172249/
Olds64 is online now
Old October 30th, 2023, 09:44 AM
Thank you so much for that advice. I was told the same and yes we ordered a spare. The new distributor worked well in hot weather all summer with no issues including long trips.
I found a company that will completely repair the weird 71/72 tank sending unit.
Will post it when I find it in my links stash.
I would rather modify the new Spectra Tank than the trunk floor if it were me. But I guess it makes sense to mess with whichever is in the worse of shape, the floor or the tank.
You know the biggest challenge in anything to do with old cars is getting a spray can of paint across the border from the USA into Canada unless you drive it across yourself in the trunk of your car lol. Like stuff from Ames or Engine Paint etc..
Cheers
Eugene
Old October 31st, 2023, 03:01 AM
tonymueller55@gmail.com's Avatar
'72 Ninety Eight
It's good to hear someone else has a '72 Ninety Eight.
I have the original single exhaust and installed an HEI distributor. I had the original radiator cleaned and tested, flushed the cooling system and installed new hoses. My next project is pulling the fuel tank and replacing the sending unit so this is welcome info, thanks!
tonymueller55@gmail.com is offline
Old October 31st, 2023, 03:13 AM
If you need engine paint I suggest POR 15. It's designed to be brushed on. They even have a few Oldsmobile colors now.
https://por15.com/products/engine-enamel
Old October 31st, 2023, 03:18 AM
Thanks!
I used POR-15 years ago on a '66 Impala and really liked it. I didn't know it came in different colors now.
Old October 31st, 2023, 04:28 AM
I stand corrected, I guess the only Oldsmobile color they have is Gold, which was used on small blocks. I painted my 455 the MOPAR Turquoise. It looks ok.
Old October 31st, 2023, 05:22 AM
Very nice looking 98. I love the 2 doors they look even longer...!
I was surprised that even after sitting so long all the rad fluid in mine dried out almost completely.
After a good flush and cleaning the rad works with no leaks and no overheating. New hoses and clamps are a must. Mine got a new water pump at the time.
I see you have cruise control a neat option.
Fusick still has all the engine compartment stickers...!
Old October 31st, 2023, 07:30 AM
Cruise, tilt/telescopic wheel AM/FM radio. It's a great cruiser.
I've always wanted the Custom Cruiser wagon but it'll never happen.
I had another '72 Ninety Eight coupe years ago, gold with a black top and interior, it was a great car to take the family cruising, the kids loved it!
Old October 31st, 2023, 08:48 AM
I love the steering wheel Tony. The steering wheel in my 98 is pretty plain-Jane and it doesn't telescope.
Old October 31st, 2023, 09:59 AM
Tony, Tilt telescoping wheel is an amazing option, along with cruise...! You are lucky. Mine only has tilt and we share the same interior colours...
Jesse yours seems to be a dry tan or is it just the sun?
I see we ALL have the same problem with steering wheel covers because that laminated wood insert dries out and falls off looking terrible.
Im trying to locate someone to fix the steering wheel for that and the backside has cracks in the plastic...
I even thought of putting on the 442 Black Sport rubber wheel with the brushed stainless ribs similar to the Grand Am wheel but IMHO it does not really suit the car.
I found a guy to restore the original AM FM Stereo with bluetooth and all that good stuff... so I can put the original one it back in.
My other complaint is the driver's seat upholstery is worn out and splitting looking a bit ratty.
Found the exact replacement upholstery at SMS got 3 yards of each cloth to reupholster the couch.
In this household its only us older things and I don't allow food coffee or eating inside anymore lol... or they get a full out dressing down.
E
Dealer Brochure showing the upholstery on my car as well
the 442 sport steering wheel
My front couch
Dash & Steering Wheel
Old October 31st, 2023, 10:27 AM
My 71 had cloth interior when I bought it. The driver's seat was damaged so I had it recovered in 2 tone brown/tan. My 71 has been in a garage pretty much every day for the past 8 years since I had the interior redone and the cloth is already starting to fade. The pic is about 5 years ago.
Old October 31st, 2023, 10:39 AM
IMHO, all the cloth materials give out in time and use...
I think the best ones are the velour types on the Regency loose cushion appearance seats for wear.
I had an 86 Regency and the beige banana boat beige was the most durable stuff I ever came across next to leather or vinyl...
But I want to keep mine stock as possible.
If $$$ was no object I would switch to the Regency type seats they look way better too...!
E
Old October 31st, 2023, 12:03 PM
I agree. The Regency seats are awesome. My father; Oldsguy, owned a 76 98 Regency coupe many years ago. I've mentioned it before and I'll stand by it, that was the BEST car I've ever driven. Probably because I was young and invincible then. 😆 If only I could transplant my spare 455 and a TH425 into my 96 98.🤔
FWIW, I think the Regency interior wasn't available until 73.
Old October 31st, 2023, 01:24 PM
The Regency Package was available in 1972 as the Y79 Order Code about $372 on page 10 of the January 1972 Specifications Book given to dealers see attached pdf if it works...
the list of options in the day was unbelievable compared to today...!
72 Regency Brochure
Stuffing the big engines into newer cars can be a fun project indeed!
E
File Type: pdf
Old October 31st, 2023, 01:49 PM
DOH! I'm all over the place today.
Old October 31st, 2023, 02:02 PM
No worries lol... I just love this stuff out there about these cars.
Cheers
E
Old October 31st, 2023, 03:20 PM
Thanks for all the info and photos!
Old October 31st, 2023, 06:47 PM
Oh my gosh... Jesse, I clicked on your youtube channel and now I remember having watched your videos working on your car...!
This was before joining this forum in the last few days... lol.
What a small world... things are more interconnected than we realize...!
Cheers
E
Old November 1st, 2023, 03:08 AM
Thanks for watching Eugene. Now that you've seen my jalopy, you know I have plenty of material for future videos. Here's a link to a thread on my YouTube channel.
https://classicoldsmobile.com/forums...thread-165144/
Old November 1st, 2023, 05:39 AM
Thank you so much Jesse. You have dug deep into working on your 98. I enjoy watching work done on these cars and look forward to more...! Keep them coming.
Eugene
jpilk99
October 13th, 2023 03:00 PM
jpilk99
Ninety-Eight
June 12th, 2023 11:44 AM
Schne442
June 6th, 2020 05:29 PM
Danny Boy
October 7th, 2010 11:25 AM
Speidy
Ninety-Eight
July 1st, 2010 08:05 AM
Quick Reply: 72 Olds 98 Best Improvements made so far
