Help replace passenger window 57, 98
Old October 26th, 2023, 09:12 PM
dart6's Avatar
dart6 is offline
Old October 26th, 2023, 09:15 PM
dart6's Avatar
Do i remove the two coutersunk screws both sides to get the cracked window out? It's a coupe with electric windows
dart6 is offline
Old October 27th, 2023, 04:29 AM
2blu442's Avatar
Sorry I don't know about the 1957 specifically, but I have removed a number of power window parts. Be prepared that there's a strong spring on the regulator that when you unbolt things it may release with a bang. I believe you will have to either remove that channel from the glass or loosen the regulator so you can slide the wheel out of the channel. Take lots of pictures of how everything is assembled to help when you put it back together with the new glass.
2blu442 is online now
Old October 27th, 2023, 07:47 PM
dart6's Avatar
Thumbs up
dart6 is offline
JW1995CutlassConvertable
February 20th, 2024 06:42 PM
Olds5798
June 8th, 2022 03:34 PM
rr69ho
January 31st, 2021 09:00 AM
PM70
December 7th, 2016 08:47 AM
ivmachine
August 26th, 2012 04:13 PM
Quick Reply: Help replace passenger window 57, 98
