Non-Olds Engines For discussion on non-Oldsmobile engines. All forum rules apply.
L86 into 71 Olds Supreme convertible
Old September 27th, 2021, 07:37 AM
CutOvers Olds Parts Guys
Bee Saint Louis's Avatar
71 Cutlass
L86 rebuilt to 2015 Escalade specs
LT1 2016 Camaro intake added
6L80e
Holley Terminator X Max
BRP Automotive engine mounts, trans mount
Kwikperformance LT1 front drive assembly
Gen II power steering pump
Old Air Products Hurricane A/C and Heat
Holley 12.3” pro dash
Aeromotive Gen II in tank 340 LPH pump
Speed engineering Headers for LT swap
Cadillac gas pedal
Will update with more information and pics as it comes along.
Bee Saint Louis is offline
Old September 27th, 2021, 12:56 PM
72cuttys's Avatar
One thing I have read countless times, is bad fitment issues with the BRP mounts. I went with UMI mounts and they were perfect.
72cuttys is offline
Old September 27th, 2021, 04:33 PM
72 Olds CS
RetroRanger's Avatar
The car looks super nice I like that blue. What color are the hood stripes ?
I didnt know what an l86 is 420hp 460 ft lbs sounds nice !
https://www.onallcylinders.com/2018/...am-specs-more/
RetroRanger is offline
Old September 27th, 2021, 05:00 PM
No stripes on this one just 2012 camaro blue (I copied my daily driver)
I didn’t know what I was buying when I got the motor just wanted an LS and end up with this and had to cram a lot of info in these last few months. So far so good on the mounts. I do have a problem with the driver side header. It’s gonna need massaging on the front cross member
Old September 27th, 2021, 08:11 PM
edzolz's Avatar
Did I see this car cruise through the NTOC show in Waxahachie last saturday? Sounded very strong.
edzolz is online now
Old September 28th, 2021, 03:56 AM
It wasn’t mine unfortunately
I wish it were me riding down to Waxahachie. I’ve been coupes up in a garage for months
Old April 24th, 2024, 07:07 AM
Currently need to get driveshaft and transmission tunnel done for 6 speed install
Anyone have a recommendation for a welder in Dallas that can weld my transmission tunnel area. Will need some fabrication done on sides.
Old April 30th, 2024, 07:41 AM
Slip joint driveshaft installed. Anyone weld and fabricate in Dallas,TX?
Sonnax 3 bolt flange with slip joint driveshaft
I recently got an impact and need to learn the proper uses for it. Do’s and don’t’s. I’ll learn eventually. Removed this from rear end, drilled out the rest of the bolt, replaced all bolts afterwards.
Old April 30th, 2024, 11:08 AM
coldwar's Avatar
Too bad your not closer to Ohio. I could weld that up in a afternoon, torches and rod or coat hanger.
Your wise to maintain a adequate airflow space around the transmission as even with good insulation on the interior side of the floor things are gonna get hot in the Texas heat, especially in traffic when air flow through the engine compartment is minimal excepting what the fan can move.
Did you maintain the same ground clearance for bottom of oil pan and trans pan, same as original? I realize the physical size of the new power is larger all the way around but it seems located high in the chassis from what little we can see.
Good luck ~
coldwar is offline
Old April 30th, 2024, 04:12 PM
Had a 4L60e in here prior to this one
It used the same trans crossmember. Trans sits higher in car than before.I sure hope i can find a welding buddy locally and inexpensive soon. Wanna ride this summer
Originally Posted by coldwar
Too bad you’re not closer to Ohio. I could weld that up in an afternoon, torches and rod or coat hanger.
Good luck ~
Old May 2nd, 2024, 07:52 AM
coldwar's Avatar
Thinking about it I have used a ±1957 Buick Dynaflow mount in place of the T-400 style mount with TH-400 and four speed transmissions, since you use the same cross member perhaps this can work and help. DF mount is a little more then a inch less mounted height. Will require some hole elongation etc to bolt to trans and CM. Never broke one, even with side stepping the clutch. Good luck.
coldwar is offline
Old May 2nd, 2024, 07:59 AM
olds_freak's Avatar
Man those six speeds are huge.
olds_freak is offline
Old May 3rd, 2024, 04:48 AM
Thanks for the tips
This created the biggest hole in the floor pan. I felt like I would never stop cutting more of it out. I cut a little too much out if you asked me. I used to do 140 in my 12’ Maro with this transmission so I’m looking to do that at the least with my 6.2/6L80e combo
GoldenHorse
November 17th, 2018 10:08 PM
costpenn
March 5th, 2016 04:02 AM
LightninS
August 5th, 2014 08:17 PM
Trebla781
July 9th, 2014 06:54 PM
projectheaven
May 18th, 2009 05:20 AM
Quick Reply: L86 into 71 Olds Supreme convertible
