Non-Oldsmobile Classified Please read forum guidelines before posting.
Vintage Atlas engine analyzer
Old January 4th, 2021, 04:37 PM
bw1339's Avatar
A friend of mine is selling a 70s Atlas Engine Analyzer. $200 OBO. Located in Commack NY. PM me for his contact info.
bw1339 is offline
Old January 4th, 2021, 08:08 PM
That's a cool piece, does it work? If it were closer I'd have it.
oldcutlass is online now
Old January 4th, 2021, 08:35 PM
Oldsdruid
rocketraider's Avatar
Not if I got there first!😍
I like. But I don't use the equipment I already have enough to justify having that gorgeous piece of garage equipment.
We had a similar Marquette analyzer when I was in auto-tech school back in mid 70s. I loved that thing. I tried to get the Sun distributor machine the school had when the Virginia community college system obsoleted it, but they hauled the thing to Richmond and put it up for auction. I could not get the time off to go.
rocketraider is offline
Old January 5th, 2021, 05:35 AM
bw1339's Avatar
Ran when parked 30 years ago
bw1339 is offline
Old January 5th, 2021, 07:37 AM
bw1339's Avatar
Sale pending.
bw1339 is offline
Old January 13th, 2021, 09:22 PM
tkcutlass's Avatar
Big Thanks to bw1339 for safe delivery.
Powered up and blew the fuse when messing with some dials. put a new fuse in today seems ok.
Can't wait to try it out may have to test it out on my 69 with the 6 banger.
Analyzer in its new home.
tkcutlass is online now
Old January 13th, 2021, 09:36 PM
Congrats on the purchase.
Old February 11th, 2021, 11:26 PM
tkcutlass's Avatar
Unfortunately, the unit keeps blowing fuses, does anyone have any experience with one of these?
Tim
Old February 12th, 2021, 04:36 AM
Very cool piece. That would look right at home in any man cave / garage.
If it keeps blowing fuses get your DVOM and start testing for a short in the fused circuit. Good luck!
Olds64 is offline
Old September 13th, 2022, 02:44 PM
Philipgruber's Avatar
Tim
Hi,
I was searching around for an Atlas Analyzer like you apparently have. I purchased one about a year ago and am still trying to get the scope to work. I think it could be the coil or plug pickup & cable. Do you still have this or know if it’s available? I just happened onto this thread.
Would love to know if I could find parts.
Thanks,
Philip
Philipgruber is offline
Old September 13th, 2022, 03:47 PM
tkcutlass's Avatar
Originally Posted by Philipgruber
Hi,
Thanks,
Philip
Still have it.
Not looking to part it out.
I haven't spent much time diagnosing.
Couldn't find an easy way in.
Do you need to take the whole top section off to get access to the circuits?
Old September 13th, 2022, 04:10 PM
Past Administrator
Oldsguy's Avatar
I have no experience with that particular device (beautiful by the way) but you mentioned "fuses" so that suggests multiple circuits are involved and that would complicate troubleshooting. I would first remove all the fuses except the main (if it has one). And check the power supply for correct voltages and current draw. This assumes you can do electronic troubleshooting. If you can't you would probably be safest to find someone who can. If you do that, the person will probably want a schematic of the unit so you should probably do an interweb search for that. It would make the job a lot easier.
Oldsguy is offline
Old September 13th, 2022, 04:30 PM
tkcutlass's Avatar
Think there is only one fuse.
I just have to spend some time to start. not a simple access panel.
I think I have to remove the entire head unit and find a way in from there.
MY google fu comes up nearly empty for anyone repairing/ troubleshooting these things.
Old September 13th, 2022, 05:18 PM
Past Administrator
Oldsguy's Avatar
Well one fuse simplifies it a lot but you still need someone who can troubleshoot that for you. Search for people who also do old stereo equipment, televisions (high voltage for the cathode ray tube), jukeboxes and pinball machines. Any of those people would have enough knowledge to to troubleshoot that thing as well, at least the power supply.
Oldsguy is offline
Old September 14th, 2022, 08:54 AM
1st, if you decide to sell it, whole, let me know. I could be interested. To answer your questions: There is only one fuse. The entire FRONT has to come out to get access to anything. Top hood, then front panel bulbs and will need to bend the contacts to clear when you putt it out forward. I have to look at mine, but I think there are screws under the front. Inside the bottom panel there is a wire schematic. There are also several vacuum tubes. Have fun finding them if any are bad. Let me know how you make out (OR WANT TO SELL IT) Or if anyone here knows of one or parts.
THANKS,
PHILIP
Old September 15th, 2022, 07:16 AM
Past Administrator
Oldsguy's Avatar
Ok I never thought of it but that makes sense that something that age would have vacuum tubes and it would be difficult to find them. I read someplace that you can still find them in Russia though. If the schematic is inside a bottom panel that would be great.
Oldsguy is offline
Old September 17th, 2022, 01:22 PM
Atlas Cables?
Im looking for the coil and spark plug ends. I’ve already replaced all the wires and get a single image on the scope. But not all 8 cyl. So looking for those parts.
if you ever hear of anything related to the Atlas, PLEASE let me k ow.
thanks,
Philip
Old September 20th, 2022, 12:50 PM
'70 4-Speed W Machine
tnswt's Avatar
Tim, try contacting Mark Saunders at mdsaunders@sbcglobal.net.
Mark is quite involved with Sun diagnostic equipment, but may be helpful with the piece of equipment you have.
Hope this helps......
tnswt is online now
Old September 20th, 2022, 03:16 PM
tkcutlass's Avatar
I'll give him a shot
Old June 13th, 2023, 08:52 AM
Tim, I don't know where you are located but you could probably find vacuum tubes and parts for your engine analyzer here.
https://epohouston.com/
Olds64 is offline
Old November 1st, 2023, 04:30 PM
jt51's Avatar
jt51 is offline
Old November 1st, 2023, 04:36 PM
jt51's Avatar
Tim,
I've been trying to contact you about your Atlas analyzer. I have an AMA 12 unit and was wondering if you still have your unit. I. have a number of cables that may fit yours.
John
jt51 is offline
Old November 12th, 2023, 09:11 PM
Satyr62's Avatar
Originally Posted by jt51
Tim,
John
John
I just bought an AMA-8. Some of the leads are pretty messed up. If you have some, I'm interested. Please let me know. Dave
Satyr62 is offline
Old November 13th, 2023, 04:14 AM
jt51's Avatar
Dave,
Where are you located? I'm in Maryland. I could email you some pictures to see if I have what you might need. Or talk on the phone. Just send me your email address. John
jt51 is offline
Old November 13th, 2023, 04:44 AM
Satyr62's Avatar
AMA Cables
Dave,
John
I just joined the site when I saw your post. I dont want to put my email or phone number on the general thread. I assume there is a way to DM you. I'll look at the site later and try that. Thanks for replying. I'm in Kansas City, Mo.
Dave
Satyr62 is offline
Old November 13th, 2023, 05:52 AM
Satyr62's Avatar
Ok
Satyr62 is offline
Old November 13th, 2023, 06:20 AM
Click on a user's icon and select Send Message to send a PM.
Olds64 is offline
Old February 23rd, 2024, 07:00 PM
jt51's Avatar
Follow up
Originally Posted by Satyr62
John
Dave
. Any luck with finding any cables? I'm still working on my AMA 12. Looking for the probe that fits the combustion analyzer portion of machine. Yours has the same unit with the CO/HO and vacuum gauge.
Here is my unit. Would really like to get it fully functional for my shop! John
jt51 is offline
Old February 24th, 2024, 02:56 AM
You could always try to find a wiring schematic here.
https://www.samswebsite.com/
Olds64 is offline
Oldsmaniac
April 24th, 2020 01:01 PM
420weblazeit
April 7th, 2014 10:12 AM
naphtali5725
February 12th, 2013 04:49 AM
Quick Reply: Vintage Atlas engine analyzer
