2bbl-4bbl swap
Old December 1st, 2008, 07:06 PM
Registered Luser
ent72olds's Avatar
Question 2bbl-4bbl swap
Other than a different throttle bracket, is the throttle cable different from a 2-4 bbl. Tranny is a th-350. I did this swap on my '72 cutlass and used a quadra-jet with no problem should it be as easy using a edelbrock(weber) 4bbl on a '70 vista...
ent72olds is offline
Old December 1st, 2008, 07:14 PM
Yes, the cable is different. You can buy one on the web used cheap or buy a new one for about 25 bucks. I changed my 2bbl to 4bbl. Other than the intake, carb, gaskets and throttle cable it was pretty much no problem. Don't forget that the 2bbl air cleaner also won't fit the Qjet. Need one designed for 4bbl.
Allan R is offline
Tim305
April 25th, 2014 03:37 PM
Tim305
February 17th, 2014 04:37 PM
boese1978
April 23rd, 2012 07:46 AM
sykosoft
February 16th, 2012 08:35 PM
cutlass1972s
July 6th, 2010 06:33 PM
Quick Reply: 2bbl-4bbl swap
