Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
Rover Engine in an '62 F-85 Cutlass
Old August 1st, 2018, 10:31 AM
  #41
WillCut's Avatar
Wouldn't the D&D or original 4 speed bell housing work with the z bar? I assumed that would bolt right up.
WillCut is offline
Old August 1st, 2018, 08:22 PM
  #42
The z-bar pivot ball mounts to the block, not the bellhousing.
I was not aware that the Rover block lacked the provision. I have a 1990s vintage T5 with the factory hydraulic throwout bearing for mine, as the clutch linkage takes up precious space for the driver side exhaust.
joe_padavano is offline
Old August 16th, 2018, 07:44 PM
  #43
Torqueline's Avatar
Joe, is correct, the ball stud mounts to the block and the Rover engine does not have provisions for this.. Also very important, as mentioned by Joe, the Z bar takes up a lot of space..
I have dual exhaust system on mine and it would have been even more of a nightmare if the Z Bar was still there.
I am using the factory, original, T-10 4 Speed tranny (for the guy that asked)
Torqueline is offline
Old November 18th, 2018, 06:29 PM
  #44
Torqueline's Avatar
Car is almost ready for final primer.. Seem I can not upload pics... they up load but do not get attached to the post.. any ideas?
Old November 19th, 2018, 02:27 PM
  #45
mattking's Avatar
WOW, what a cool looking car... I have never even seen one before.....
mattking is offline
Old August 31st, 2022, 09:51 AM
  #46
Eff-eighty-five's Avatar
Hi,
Interested in more information on your radiator. I made out "Champion" on the cap, same mfr as radiator?
Thanks.
Eff-eighty-five is offline
Old August 31st, 2022, 12:00 PM
  #47
Torqueline's Avatar
This is the one I used.. Only had to use a silicone elbow at the lower outlet
https://shop.championcooling.com/Per...mpest-SKU-6163
Old August 31st, 2022, 12:08 PM
  #48
Thanks!
Old August 31st, 2022, 03:06 PM
  #49
Very nice work.
oldcutlass is online now
Old March 30th, 2023, 03:59 PM
  #50
JefireDreams's Avatar
Looks amazing! If it helps anyone, then the front covers and sumps can be fitted to late model 4.0/4.6 Rover V8 distributor-less engines, as can some Buick V6's as they were derived from the V8's. The V6 also has a helpful side mounting oil filter mount that can help with clearance issues.
JefireDreams is offline
jcdynamic88
December 31st, 2018 11:18 AM
Joseph Clark
Non-Olds Engines
April 3rd, 2017 11:34 PM
75 W-30 H/O
January 23rd, 2016 04:45 AM
abosron
November 16th, 2010 04:41 PM
63 F85 Cutlass
November 4th, 2010 11:21 PM
Quick Reply: Rover Engine in an '62 F-85 Cutlass
