what paint to use on backing plates
I was planning on using VHT caliper paint since they might heat up slightly, but I suspect not that much. Any advice on the need or no need for heat resistance? I am painting everything under the car with with SPI black epoxy primer and that will also be the finish coat.
JpMotorsports
May 15th, 2014 07:08 AM
