403 vs 403
403 vs 403
I’ll be doing two 403’s, one with iron heads, one with new Edelbrocks. But some other differences as well. However both will have RPM intakes, and all roller valve trains.
I’ll post both sets of build specs in the coming days.
Here are the build specs for each;
Build 1)
#5 mildly ported irons
Hyd roller, 227/234@.050, 108lsa, .576/.573 lift
10:1
RPM intake
QF Hot rod series 750
Build 2)
Out of the box Gen III Edelbrocks
10:1
Hyd roller 233/238@.050, 110lsa, .587 lift.
RPM intake, minor port matching
Holley Terminator TBI
Both will be blowing thru my 1 3/4 dyno headers and 2.500” exhaust.
Should have results in the next 7-10 days.
Build 1)
10:1
RPM intake
Build 2)
10:1
But I don’t see it happening, mainly because I’d have to use flat tappet cams in all three to keep it legit. Can’t do a roller for the .921 block. Like a lot of others, I’m not doing flat tappet builds anymore. Sorry.
2, 400 E
3. 400 G
I would agree with that ranking, assuming all three used the same heads. There will be a difference in the intake, naturally.
I can get solid roller lifters for a .921 block but they’re very pricey, about $1500.00. Not sure I want to bite that bullet either unless someone wants to buy that build. Just sayin.
They didn’t change the valve centers vs any of the earlier designs.
