Holley Sniper 12-373 in-tank efi pump
I'm looking at this to convert my 1970 convert to Sniper EFI 550-510 system. It says it fits a 1970 chevelle, monte carlo, el camino AND GM A BODY. So I would think they would fit. Just like to double check to see if anyone has used one before I order one up.
Thanks, John
Thanks, John
The Tanks Inc tank and internal fuel pump is one of the few things I have no complaints with the EFI conversion.
If I remember correctly, they have 2 different tank designs. One looks very similar to a factory tank, the other has the lower front corners trimmed for additional exhaust room.
Id strongly consider upgrading to the float less style sending unit. The float on the standard sending unit isn’t very accurate below 1/4. From what I have heard, the float isn’t heavy enough to fall on its own once the fuel level drops. Some people have “fixed” this with brazing a large nut or washer to the float arm.
It’s embarrassing to run out of gas!!
Sorry, work, life and slow upgrades I haven't moved forward with EFI yet.
Still note sure if I would go this route with the intake Holley pump for my Sniper? I do have an external 450l pump now, so do I need to spend the $$$ for this? BUT more importantly is I might be swapping out the tank and therefore the Holley system might not work with the different tank.
