New Edelbrock heads flow specs
#82
#83
The reason I posted the picture was because people had questions about the performance capability of the newly designed Edelbrock head. We should find out soon how well they work after being in Bills capable hands.
#84
This is an in process picture, I do not know if Bill will be posting any fully ported pictures. We should be able to see how the new heads perform after the engine that they go on hits the dyno.
#85
Post from BTR Facebook
Done. 8 pulls. Dyno carb used. I just don't know when we will be getting the Holley Terminator stuff so we wanted to finish and ship while the weather is good. All in all, I'm happy with the new design Edelbrock heads. Normally these 468 engines make about 510 to 520 with 10.7:1 and a bigger cam. This has 10.35 with a small duration camshaft for better driveability with a stick. Too big of a cam makes it an assache to drive allthough it makes more power.
Facebook Post
#87
No, as much as I know and was stated, this is an apples to apples test when it comes to the cyl heads only. He does a valve job, some clean up and changes springs I believe, but the same on both nonetheless.
And earlier in the post he mentioned he didn’t like some of the changes that were made. Now he does, go figure.
Finally, good luck getting cam specs from him. He hardly ever shares those.
#89
#90
#91
#92
Maybe you could answer my question, then. How much better, in horsepowers, are the new heads over the old?
#93
Sorry, NO I can not. I know what I know and Olds are new to me. But those who do have posted what they know or felt since they have used both. EVERYTHING I have has modified heads, even my daily driver 2010 Ram 5.7 Hemi. I would never use a head that hasn't had some work do to it.
#94
[QUOTE=cutlassefi
That comment was made prior to dyno results, but you already knew that.
#95
I found it interesting when guys would lower their ET by not running as much gear, switching to smaller cam or reducing header tube size etc.
#96
[QUOTE=Bernhard;1462740][QUOTE=cutlassefi
That comment was made prior to dyno results, but you already knew that.[/QUOTE]
Correct. But you would hope that he could’ve just not said anything until he had Dyno results. Oh well.
#97
Here's a question: were the valve cover rails raised? Ben and I were discussing this as we're both running stock valve covers with spacers just to get good baffling. All the aftermarket baffles suck.
#98
As mentioned though, additional material was added between the rocker stud bosses and vc rails so raising the intake entry can be done if desired.
#99
#101
Guys, you have to remember these are mostly going on stock or mild street/strip applications. I don’t know if any of you have done it, but you can actually modify the stock tin valve covers to work on these heads in most cases. That needs that to be the case so people don’t get deterred from using them on something less than an all out race application. It is what it is.
#102
that was just a little joke i was saying to Fleming
#103
Bottom line is, this is a better head than the one it replaced in a bunch of ways, while still retaining stock locations. Win-win.
#104
#105
Yeah, I'm still looking for a reason to buy some. 🤪
#106
I do not have a part #,got them used from my engine guys and I believe they are Chevy.
#107
#108
Makes total sense why would a professional engine builder give away his cam specifications. You want a BTR cam buy one same goes for any engine builder not just BTR.
#109
Like I said I guess, everything is a learned behavior isn't it? So a guy asking just may be wanting to build his own cam manufacturers give out specs rather you buy from them or not. And some professional engine builders give advice also reason I said I guess. It only really has to make sense to him, but if I'm asking because I want to learn to build my own engine then there's multiple ways to get information.
#111
yes David Vizard has plenty of videos giving Intel on how to select cam specs. Sometimes people ask questions for confirmation not from just mere ignorance. So if any man think I'm going to spend thousands with them for information that's clearly plentiful from other professional engine builders that's actually not trying to make EVERY DIME. As I said "I guess" if it makes sense to you that's all that counts but it's mighty strange our community is as limited as it is maybe it's because some are actually that petty. But to each his own I do respect what I may disagree with
#112
I competed against him in the RACE engine challenge with an Olds and smoked his Chevy butt. He even borrowed our carb because his numbers were dismal,, it helped to keep him out of last place,,,finished 2nd to last. With a small block chev that was supposed to be something real special.
in that years competition all competitors were supposed to receive a free Vizurd cam selection software program that he touted as the ultimate cam selection software ever developed.
I never recieved it, after asking multiple times. As far as I know, nobody else got one either.
Bullet cams has some fairly good tech advisors that can help you out
#113
you would be better off calling a cam company’s tech like than believing anything Vizurd says.
#114
#115
I’ve had the unpleasant opportunity to sit through some of his seminars at these competitions. I would rather have a root canal than go through that again. The guy is a fraud and a shyster. He has no shop, no equipment..he borrows equipment and shop space from others to do his work and videos.
he’s a well known grifter in the Charlotte area. He calls himself an ex aerospace engineer and talks of all these racing championships he won in Great Britain. Funny thing is, you won’t find any proof of that. I’ve been told by more than a few people who’ve known him for years that he’s a straight up bs’r
for years he talked of entering the Engine masters ,, but never did. Hinting that it wouldn’t be fair to the other competitors. Well he finally did enter the RACE engine challenge..I seen him in action …what a dumb ***. He’s a great talker though.
they even gave him and his team twice the allotted time on the Dyno to try and sort their dog of and engine out. They finally asked around if anyone had a carb they could borrow,,so ya, pulled off the carb from our engine. A real trick Dale cubic piece and brought it into the cell for him to use. It did help a bit , but he ended up at the bottom of the standings.
#116
I ATTEMPTED to sit thru one of his sessions at the last PRI. It was on valve sizes vs flow vs the size of your Christmas tree vs your Tgiving turkey, or something like that. He was talking in circles so I left before too long. He’s a blowhard.
#117
#118
I have always used camshafts designed by engine builders versus large cam corporations. I used Dave Smith camshafts as well as a few Jim Bell KB camshafts.
#119
Cam manufactures give out cam specifications to there generic camshafts not there one off profiles. They also sell cams in large volumes so it's no big deal if you copy one of there cams. BTR builds Oldsmobile engines that are tailored to the customers goals. There are others on Classic Oldsmobile that I would be very surprised if they were willing to share there hard earned knowledge around camshaft design. Some members on this site and real Oldsmobile were very open with what cam they were running but they also were not running a business.
#120
