PDD CCN manufacturing
Old January 28th, 2024, 08:07 PM
Bernhard's Avatar
Bernhard is offline
Old January 28th, 2024, 08:11 PM
Bernhard's Avatar
Bernhard is offline
Old January 28th, 2024, 08:12 PM
Bernhard's Avatar
Bernhard is offline
Old January 28th, 2024, 08:21 PM
66-3X2 442's Avatar
Peyton Hunt has it goin on doesn't he? Great young man too.
66-3X2 442 is offline
Old January 28th, 2024, 09:28 PM
Bernhard's Avatar
That's some very impress parts manufacturing. I'm looking forward to this build as well as others on Facebook.
Bernhard is offline
Old January 29th, 2024, 04:55 AM
chadman's Avatar
Originally Posted by Bernhard
When I look at this I can't help but think of all of the oil and dirt that's going to end up in the pockets on that valley tray. Definitely some nice machine work though.
chadman is offline
Old January 29th, 2024, 09:11 PM
v8al's Avatar
Personally, I like to see heads that have holes drilled for the accessory brackets. Though for all out race I understand why they are not present.
v8al is offline
Old January 29th, 2024, 09:39 PM
Bernhard's Avatar
Motor plate at this power level.
Bernhard is offline
Old January 30th, 2024, 05:56 PM
Mr Nick's Avatar
Some sort of removable plate at the end of the heads?
Mr Nick is offline
Old January 30th, 2024, 06:53 PM
olds_freak's Avatar
But the question EVERYONE wants to know is: Will these clear a mechanical fuel pump?
olds_freak is offline
Old January 30th, 2024, 06:54 PM
olds_freak's Avatar
Yes. They're billet so they have to do that to be able to machine water passages.
Old January 30th, 2024, 08:20 PM
66-3X2 442's Avatar
Absolutely!!!!!!!
Old January 30th, 2024, 08:24 PM
Bernhard's Avatar
Nice LOL
Bernhard is offline
Old January 30th, 2024, 08:37 PM
CANADIANOLDS's Avatar
post any build info if you know
CANADIANOLDS is offline
Old January 31st, 2024, 04:21 PM
Battenrunner's Avatar
Those are some gorgeous pieces.
Has he released any info about cross-section area, flow numbers, pricing, etc?
Battenrunner is offline
Old January 31st, 2024, 05:30 PM
66-3X2 442's Avatar
They have a website.
Old January 31st, 2024, 06:12 PM
I didn’t know they have a website separate from Facebook. I am not on Facebook, and I couldn’t open their Facebook since I am not on there.
here is a link to their website, for others who don’t want to be trolled:
https://www.performancedrivendesign.com
Looks like the heads start at $10,500, and that doesn’t say what all is included or done to the heads.
Really nice stuff from him in general. If I had the funds, I would do the heads on a Rocket block.
Old February 1st, 2024, 03:27 PM
the heads would be designed for your specific app. So wanting to know what they flow or anything else would need your engine details and power goals
there is such a thing as too big of a port and valve for an engine. Those heads on a 400” short stroke or a big 540” big block would be different. Min CSA and max intake valve size is critical…even though many experts on here don’t know what that even means. Air speed through the intake port needs to be right for the cyl volume and rpm..if it , it could be lazy , peaky..or be a dud all together
the reason you see flow numbers for Edelbrock and Speedmasters is because they are usually low on flow #s even after a max port when installed on a big block…they need to be blasted out so the engine doesn’t fall on its face up top.
Old February 1st, 2024, 03:41 PM
They heads are an ODE to ROP😂😜
that’s great…😎
Old February 1st, 2024, 06:19 PM
yessir…sounds like they are fully custom and optimized for each build, which makes them really even more impressive.
I do know a wee bit about that max intake valve size to CSA ratio, but I do appreciate your info and sharing.
Yep, getting these weezy-azz Olds factory port location heads above 300cfm takes a lot….
Even the Battens don’t usually go much above 380cfm with max effort and .800 lift, at least for ones I have heard about and spoken to people on.
Old February 1st, 2024, 09:04 PM
66SportCoupe's Avatar
Pick a nice big build and figure out other things needed for a smaller build. Pretty simple.
66SportCoupe is offline
Old February 1st, 2024, 09:42 PM
what?
75 W-30 H/O
November 18th, 2023 01:37 PM
tkcutlass
September 20th, 2023 08:09 PM
75 W-30 H/O
November 23rd, 2022 03:47 PM
72455
March 14th, 2022 12:42 PM
Quick Reply: PDD CCN manufacturing
