Head bolt torque and sequence?
Old March 7th, 2011, 03:00 PM
Franks425442's Avatar
Hey all! I was hoping that someone could give the proper torque (I think its 80 ft/lbs) and what sequence to torque heads on a 425?
Franks425442 is offline
Old March 7th, 2011, 05:04 PM
geckonz08's Avatar
Frank, 95ft/lb.
I am having trouble in describing the sequence but starts in centre bolt between valves ,then other bolt opposite , centre --near xhaust . Sorry buddy we need a pic for this
mike
geckonz08 is offline
Old March 7th, 2011, 05:05 PM
Charlie_brown's Avatar
Work from the center bolt in a spiral pattern out. Someone correct me if i wrong.
Charlie_brown is offline
Old March 7th, 2011, 05:06 PM
geckonz08's Avatar
hang about
exhaust side
10 4 2 6 8
9 3 1 5 7
intake
Old March 7th, 2011, 05:12 PM
use this
http://www.442.com/tech/torque.html
and this for sequence
http://www.jegs.com/InstallationInst.../350-60529.pdf
Old March 7th, 2011, 05:36 PM
80-85 ft lb; gecko has the right sequence.
Old March 7th, 2011, 09:41 PM
geckonz08's Avatar
Hey it`s strange .My 66 C.S.M. says 95FT/LB. You n other references quote 80- 90.
Which is correct?
Is it to do with oil on the bolts /or not ?
Is it concerning a 7/16 or 1/2 " bolt ?
Is it not that critical ?
Pretty keen to find out b4 I let the builder loose with my C.S.M.
CHEERS MIKE
Old March 8th, 2011, 04:09 AM
Here's what the '66 CSM says:
Old March 8th, 2011, 08:27 AM
My 66 csm has 80 ft lb in the text and in the summary at the end of the section. Definitely clean the bolts and block, oil the bolts, threads and shoulders, and let them drain onto a paper towel before installation.
Old March 8th, 2011, 11:09 AM
geckonz08's Avatar
THANKS .I am wrong again and apologise to Frank when I said 95 ft/ lb torque.It is 80 as others have stated. I did the classic "too fast n no finesse" when I mistakenly looked at the 66 L6 --Not the v8 -425.
mike
Old March 8th, 2011, 01:13 PM
blueRAYwhale's Avatar
Smile bolts
torque bolts in a three stage circular pattern, from the center of the head outwards. so like 30, 60, then final...add 5 lbs. if you re-use bolts. 80 lbs. sounds about right.
blueRAYwhale is offline
Old March 9th, 2011, 06:11 AM
greenslade's Avatar
be sure to blow out the bolt holes before installing heads
greenslade is offline
Old March 9th, 2011, 11:31 AM
Smile yeah
i even heard of dudes runnin' a flat bottom chaser tap to clean-out the threads. i've never done that, i did like you said and used compressed air to clean out the holes along with a good blast of Berrymans chemtool. never had a problem with that method and even reused head gaskets. i think olds. motors have good clamping pressure around the cylinders so maybe torque isn't so critical. i know my torgue wrench is like +/- 10% at best, on a good day, so who knows.
Old March 9th, 2011, 11:41 AM
I'd definitely run a tap through the threads first.
Old March 9th, 2011, 12:08 PM
Thanks for all the help guys! This site really helps a lot! You can find thousands of websites and info on bowtie motors at any given time, but you really gotta dig deep in google for some reliable olds info!
wcourt3010
April 13th, 2015 12:10 PM
Don Roberto
April 11th, 2015 09:48 PM
ctreutel
June 26th, 2013 04:01 AM
major tom
August 13th, 2010 10:04 AM
nukesec1
October 6th, 2009 12:42 PM
Quick Reply: Head bolt torque and sequence?
