1977 350 rebuild
1977 350 rebuild
iam rebuilding a 1977 or 76 or new or older i downt know i pulled it out of a 79 buick it run grate when i got it now it has a slite nock and cant burnout any more so i have engine out this is my first build i woold like to do a complete performance rebuild so i need to know what to get and a good place to get them?
First you need to find a good machinist that knows there is a difference between rebuilding a Chevy motor and an Olds motor. Many shops use generic Chevy tolerances on the Olds motor and ruin it. Same goes for the heads. Experience is worth it in this case. Second you can get a complete rebuild gasket kit at Summit, or other speed sources for that matter. Third you should determine exactly how far you are going to go with the rebuild concerning all your hang-ons. New water pump or re-use the old? New fuel pump? Same A/C stuff or are you planning on changing anything while the engine is out? etc, etc. The job will be much easier if you have everything ready and don't end up getting an aftermarket manifold like a torker and find out you can't fit your HEI distributor on it. Anyway, you know what I am getting at. Good luck and hang around and get help from us, that is what we are here for.
ybicutty
October 12th, 2012 05:11 AM
