BLUE SMOKE (long thread w/lotta detail)
Hello again This is no smiling matter.
77 350 (99,000miles) is blowing blue smoke out the exhaust pipe while sitting at stoplights. I pulled all the plugs and it looks like ONLY the #1 plug is covered in oil. B4 i had the intake(RPM), carb(750 man.choke edel.), fuel pump, distributor cap, rotor, wires and of course plugs all replaced, compression was checked on all cylinders and was fine. "When doing compression check I was told to use oil can and squirt oil into each cylinder in spark plug 'hole'." SO I DID
This was when the smoke problem all began!!!
All the way to the shop it smoked. After I started for the first time from the shop it smoked constantly for 20 minutes and 10 miles now only smokes when driving and then come to a stop, NOT when it's in motion or when started up and allowed to idle. I replaced all the plugs ran fine for a couple of drives, and now back to smoking, again ONLY #1 plug covered in oil. Could it be the oil burning off in that cylinder, OR could this be a more serious problem?
Where should I go from here?
Drain some oil out and run a bunch of motor flush in it. Idle it for 10 minutes, and change the oil. Then get a can of B12 chem tool, pour it in a dog bowl, & pull out your pcv valve leaving it attached to the hose. Have a buddy keep the rpms up on the motor while you let the pcv suck up the chemtool out of the dog bowl. That should yield a good amount of smoke, but your motor will be nice and clean if you have to rebuild.
One time My kid brother topped off to the filler cap, SAE 30 in the lawnmower and it was smoking blue like CRAZY. It was ruined after that. It would only run with the oil fill cap off for some reason, and it's no good mowing the lawn with oil and grass/dirt spattering everywhere.
I'm thinking it could bad a bad valve seat, I doubt it would be bad rings/walls on just one cylinder... What do you guys think? I also think that it is not a good idea to put anything in your oil, I am told that this is instant knock for older cars. I am not sure and I wouldn't recommend it without a second opnion, But is is it possible to run a hotter plg in cyl #1? What you guys say?
keep the replys comming
thanks for all the input and suggestions.
If it turns out that I have to rebuild, then where should I begin?
What steps should be taken to ensure the process will be worth the money spent...
to own a 350hp '77 block that will be driven daily with an iron foot.
I agree with you on the "mystery oil" additives. Masking a problem is NOT a good idea!
C.J.
You didn't state the results of the compression test. If we are to assume they are within accepted standards, I would have to guess a badly worn intake guide or valve seals. Then only the top half would have to come off for rebuilding.
Hi. Did you put in the oil before the compression test? The procedure is, 1, do a test to all 8 cylinders, no oil. record readings. 2, add a bit of oil to each cylinder, and do the test again. The oil is added to the second test so you can test valve compression. Adding oil will bring up compression if your valve seals are ok. Do a dry test, just to be sure, but my guess is a valve seal job, not a rebuild. Let us know. jim.
In VA, till friday and planning pulling the {3A}heads beginning SAT morning...
Tested all cylinders once, and pressure rose and held steady in all cylinders.
Tested Again, using oil, and pressure rose and held steady in all cylinders.
Pressure fluctuated + 0 to +7(Hg measurement) AT most as motor was cranked, but it rose and held steady. SOMEONE lost the numbers, but pressure rose +10( ) total most between highest and lowest reading cylinders.
I 've seen that happening when testing the not failing, but the lesser performing valves of the same quality in mechanical fuel pumps.
??...to the machine shop for a cylinder head updo?
Gonna let everyone know the deal soon as I get at it
