Which 330 engine
More info on what you have would help. What style Cutlass? Especially pictures. If it's a 4 bbl then it's more than likely 10.25:1 compression with 320? HP?
I'm a little foggy in this area as I haven't been in the engine loop for the last several years.
Somebody else with better knowledge than me will chime in eventually.
Forced induction??
Check the wiki site for a comparison of small blocks if your not sure what to use. If you have the time you can read throught the big block section too.
http://www.oldsmobilewiki.com/index....st_Small_Block
Try this FAQ from 442.com. It should answer alot of questions.
http://442.com/oldsfaq/oldsfaq.htm
These pictures I took from my assembly manual should definitely help you to ID the exact 330 engine you have providing it's the original motor. Hope this helps
Also hoping this will help anybody else out in the future
Let us know how you make out.
rustycragars
December 25th, 2016 06:06 PM
thomaswatk
March 22nd, 2007 01:31 PM
