371 performance
What is your goal, and your budget?
Depending on your intended use, a rear gear change will put more of your existing power to the ground, but a good ring and pinion set for '57 to '64 may be hard to find.
Dual exhaust should be on any V8.
Carb re-jet and re-curved distributor (done by someone who actually knows what they are doing) will get you the most bang for your buck.
Norm
Norm
So true, and many shops don't even do "old style" distributors any more. I remember when there was a distributor machine in every shop. Must be a vanishing skill, sort of like people that know how to work on vacuum tubes.
But that was when every guy drove a '57 Chev, and every girl wore a "Poodle Skirt".
One that I (among others) will, likely, be taking to my grave.
Another area where progress = moving backward, because a simple fact (analog sound reproduction is more accurate than it's digital equivalent) got lost.
Norm
You can get lighter distributor springs from Mr. Gasket and probably other places. Current MSD and Accel distributors use centrifugal weights too. Go with something medium, not the lightest springs, and drive it to determine the best curve, just like the factory did, at least in the 60s and 70s.
Isky still makes camshafts for the old stuff.
Why should shops continue to keep people skilled in servicing distributors if cars don't even have them anymore? They haven't had distributors for about 15 years.
Really, I understand where you all are coming from. It seems the skills associated with our hobby are getting harder to come by professionally.
The ONLY reason for electronic engine controls is to meet emissions and keep the car in spec for whatever arbitrary time EPA thinks it should be today. They're bad as NASCAR about making up rules as they go.
I like the electronic computer controls on the newer cars that I have owned.
93 Buick LeSabre
94 Mercury Sable
94 Chrysler LeBaron
03 Volkswagen Beetle
All of the above cars got 25+ mpg on the highway. That is a good thing with gasoline at $4.00+ / gallon. A car with a points distributor and carburetor could never do that.
93 Buick LeSabre
94 Mercury Sable
94 Chrysler LeBaron
Here's one for ya. I owned a Speed shop until about a year ago. I sold it. Anyway, I had my Vette in there and asked one of our WYOTECH Techs to change my distributor while I was at lunch. I was changing to an MSD unit. He said he had to wait until I or my shop foreman were around because he wasn't sure how to do it. In fact had never done it. The new electronics kick ***. I have MSDs and electronic ignitions on all my stuff. To his credit he could do an LS1 cam swap in an afternoon.
Too bad that Wyotech guy didn't know how to change a distributor. I guess they only train them on what they see most often. Oldsguy has a friend that teaches at a vo-tech center in Kansas City, MO. He is a good guy. He knows alot about cars and hot rods too.
im used to the 5.0 performance options which is endless. Ill surely get a recurve kit, I never even thought about it. definately cheap (under $10) and something new to learn about.
I just pulled the car out of the shed and got it running again so the family can enjoy it and i thought a little more power wouldnt hurt
wmachine
December 30th, 2009 05:55 AM
