403 gasket set
Those aren't bolt holes. Those are for the dowel pins that locate the heads. The 403 block doesn't have a dowel pin at that middle location.
if that engine hasn’t had the deck cut, you’ll be about.040” with the cometics and over .060” with Felpros
Measure how far the pistons are below deck and decide from there. The Felpro are .042" compressed, Mr Gasket MLS .040" and Cometic are available as thin as .027". Cometic and Mr.Gasket offers full Olds Gasket sets as well as Mahle, just not with the unique 403 head gaskets.
It looks like the KB pistons are about .010 taller than most of the other aftermarket replacements. If I did the math right they should only be down in the cylinder about .005" so the Fel Pro gaskets should be fine. Just want to mention that the Fel Pro 260-1104 gasket set does not include a valley pan or any type of intake gaskets.
Factory are .018", Cometic's are expensive and still .027". There was a guy who used to have .011" thick that I bought but no longer offers (Smitty?). Another option is just cutting the cylinder head .024" to make up the difference in gasket thickness from factory to the inexpensive Fel Pro.
To be honest with you there have probably been thousands of Olds engines rebuilt using the Fel Pro or other composition gaskets and I would bet that in 80% of applications it really does not make any difference. If you are building a high compression engine and looking for every bit of horsepower you can get then by all means worry about it. Otherwise the Fel Pro gaskets will work just fine and to be honest with you unless the head and block surfaces are freshly machined I think you are taking a chance on the metal shims.
That really does not affect the "squish" or "quench" (piston to cylinder head) dimension which is why guys want to use the thin gaskets.
Here’s the truth . The lower the compression, the more critical it is to have minimal quench. The bigger the bore, the more critical is it to have minimal quench. So both of those are present with the typical 403.
the higher the compression, the less the need for quench..infact, a tight quench on a high compression engine can have negative consequences.
on a high compression engine the molecules in the chamber are very active , that’s why there isn’t the need for a tight quench. On a low compression engine, there is very little of that, so you need the tight quench to help create activity or get the molecules moving.
the real benefit is the activity from the tight quench, not really the additional compression..but it doesn’t hurt.
and..the felpros are not .042” compressed. I’ve told you that before and why they’re not.
And to measure the compressed thickness of a Fel pro, gasket, their techs will tell you to take a dial caliper and measure them new just behind the fire ring. Then deduct .005 or so from that.
Sorry but you didn’t. Half the stroke is 1.6925, plus rod @ 6.00, plus cd of piston, 1.615, and you get 9.3075, or at least .020-.025 below a normal SBO deck height.
Clark455
April 7th, 2023 07:20 AM
aussiemobile
February 15th, 2013 07:31 AM
