Degree stock camshaft?
Old March 5th, 2015, 04:47 PM
SkylinesSuck's Avatar
Is it worth it? I have and adjustable double roller set and everything apart on the engine stand now. I heard some years Olds decided to retard the factory cam for emmisions. Is it worth degreeing to make sure it's actually straight up? I would have to wait 7-10 days for a degreeing wheel and dial indicator to show up is the only real negative.
SkylinesSuck is offline
Old March 5th, 2015, 05:35 PM
cjsdad's Avatar
Don't want to be just another number that looked, but didn't reply. I don't know if the factory cams are typically accurate enough to install without degreeing in, but it sure can't hurt.
cjsdad is offline
Old March 5th, 2015, 05:37 PM
In general, you should do it, if only because that way you're sure that it's right.
Once the engine's all buttoned up and installed, any tiny doubts you may barely notice can gnaw at you.
And, on that note, you should photograph the chain and gears once it's all set up, in case you wonder later, "Did I...?"
ps: I used a fancy adjustable gear setup on my current engine, and the first time I set it up, I lined up the wrong dots with each other. I would have closed it up that way, and then wondered why it didn't run, and totally screwed myself up because I was on a schedule, but I degreed it and saw that it was off (and then had to figure out why...), so that's another reason to do it.
MDchanic is offline
Old March 6th, 2015, 09:26 PM
Yes, definitely degree the cam. It doesn't matter if it's a stock rebuild or a max performance build, if the cam is not correct the engine won't perform as it should.
I once installed a cam with a generic stock replacement timing set and the engine didn't have much low end power. Later I checked the cam (degreed it) and found that it was 8º retarded, which explained the reduced low end power. Had I checked the cam when it was installed I would have found the issue and not suffered with reduced performance for many years until I corrected it. I don't know if it was the camshaft that was off or the timing set that was off, but not even knowing that it was off was he biggest mistake.
Fun71 is online now
cecilsclassics
September 28th, 2014 04:45 PM
shamusj
September 11th, 2014 04:05 PM
jhoppeolds
August 21st, 2014 05:26 PM
joepenoso
May 13th, 2012 05:26 PM
rt38 classic engines
May 9th, 2006 05:28 PM
Quick Reply: Degree stock camshaft?
