Engine swap help
Engine swap help
So I had an 81 cutlass that I rolled last week so I’m in the market for another car I found an 84 Buick Regal with a sbc that need to be replaced what would I have to do to put the olds 350 and trans from my cutlass in it
You need the frame mounts off your 81, all your accessories, motor mounts, brackets, engine hoses including the A/C compressor, well at least the A/C hoses for an Olds V8, the sbc compressor should be the same. Otherwise it is extending wires as necessary and paying attention where everything goes.
