Nascar 350 dx build 8,000+ rpm
Old February 3rd, 2023, 02:35 PM
  #81
66-3X2 442's Avatar
Originally Posted by HighwayStar 442
I you remember finding a drag time slip in my car that you built. But no longer have it. Did you just drive my car 1/4 mile at a time
1/8 mile @ a time. That was a street car.
66-3X2 442 is offline
Old February 4th, 2023, 07:00 AM
  #82
HighwayStar 442's Avatar
Lift is only a small part of cam choice.
For reference I just did a SBO 428 inch Stroker with CNC’d Speedmasters and a 242/249@.050 Hyd roller on a 109 with .625/.620 lift. It peaked at 6100 with a decent Victor and 850. Yours may spin to 8k but it doesn’t mean it’ll still be making power there. In order to do that you need something well into to 250’s+@050.
Just sayin.
You are talking apples to oranges. The only thing the same. Its a 350 olds size block. As I said some were here before. Peaking around the same rpm as yours. But maintaining that peak HP or at least close. Up to the 8,000+. HP around 650. My engine will still be pulling, past 6,000 or so rpm. Where the one you did. HP will start to decrease.
Batten heads and intake are better flowing. The greater the cylinder heads' intake-port flow, the less cam you need to make the same power at the same rpm. Higher-flowing heads will raise the rpm points where peak torque and power will occur. Batten have improve flow giving the air/fuel mixture more of a straight shot.
And not a stoker. A little less volume needed in the cylinder. 2-inch headers. Strong valve train with lightweight components. Without valve float to 8,000+ rpm.
Time will tell on the Dyno.
HighwayStar 442 is offline
Old February 4th, 2023, 07:33 AM
  #83
rickw30's Avatar
John, don't let these guys crawl up your *** !
Some of these guys have never even seen one, let alone built one.
Back in the day A.J. banged this block all day long at 8k.
You picked Bill to build your motor for a reason. For the same reason as that other Nascar block video that was recently posted.
If he tells you it's gonna do one thing, that's what it's gonna do. Period !
If you don't tell him what you want then he'll do what he wants.
And for those who are about to say it... No, Bill isn't the only guy who knows his way around this type of build. But he sure has done a lot of them.
rickw30 is offline
Old March 21st, 2023, 12:53 AM
  #84
sean Buick 76's Avatar
Exiting build! Being a newby can someone enlighten me on the difference between the nascar DX blocks vs the regular 350 Olds? Also where does the diesel block fit in?
I did a Buick 350 for boost and 8000 and this girdle helped as it’s a 2 bolt main. Glad you didn’t have to go through that hassle.
sean Buick 76 is offline
Old March 21st, 2023, 02:59 AM
  #85
Hi, Welcome aboard! Like your Buick! Broke my street racing cherry at 16. In my parents 1970 Skylark Buick 350 GS. Was 1 in a 100. Hotter than most 350 GS right out of the factory. Must have been a Wednesday build with all the right parts coming together. Buick's had more torque than Olds. Loved that Buick!!!! Bad luck with distributor in front of engine in the rain. Would have kill myself in yours at 16 years old.
See the first thread photos. The oil pan rails are massive on thenascar HP DX blocks. With 4 bolt main caps already built in. Other areas in the block are also thicker. No need of what I call a band aid. Oldsmobile V8 diesel block is externally the extra dimension of a Olds 350 gas block. Including this HP Block. So one size fits all. Normal DX and D diesel block are great for high horsepower also. And no need of a band aid. Others have more info than me. I am just a fire sprinkler design. But I know what I want.
Old March 21st, 2023, 06:55 AM
  #86
oddball's Avatar
The Olds 350 D and DX were the production diesel blocks in late 70s through 80s. They can be converted for gas use quite easily, but they are production diesel engines. The main webs are much, much thicker and the cylinder walls are thicker than the gas block castings. Still 2 bolt mains, uses 3" main bearings. Lots and lots of these diesels were made, so it's not too hard to find a core. There were a lot of mistakes with them so they got a (well deserved) bad name and got junked pretty quickly.
Olds sponsored Nascar racing and provided the Nascar/HP block which is a variation of the DX where the casting is made for gas use (no injection pump boss), and were made with several different main bearing diameters. Not a whole lot were made, and usually they get modified or set up to match the owner's specific combo, or have a hole in the side. You usually have to find a fresh casting that may only be partially machined. So these are much tougher to track down and usually take quite a bit of work to get ready.
If you're going for the ultimate small block build then those are the only options. The big block fans have the Rocket Racing block now.
oddball is offline
Old March 21st, 2023, 11:36 AM
  #87
Thank you very much that’s great info! I’m in Edmonton btw! A few Canucks on here I see!
That’s so cool, I love hearing stories from the old school especially Buick small blocks!
I got hooked on turbocharging v8s so I like to start with a sound foundation. I hope you don’t mind my question in your build thread. I will start a thread once I get a better plan. I have a 455 Olds on the stand but I prefer the option of a boosted DX 350 with a stroker kit. I’m also considering using a stock stroke as I’m only looking for about 650 crank Hp with 7psi. I was impressed by some of the Hp and TQ numbers from the iron head SBO engines and I think boost could really wake them up further.
Back to your build, sorry for the off shoot.
I think your build is on track and it sounds like the builder is helping you reach your goals. Many times we get caught up in a million people’s opinions and just end up with a miss mash of parts that’s don’t work cohesively together. It’s easy to get caught up in numbers, specs and data but at the end of the day a good builder will help you meet your goal. Here’s a perfect example: I had a custom cam ground and he asked me about 10 questions about the car. The use of the car, weight, gearing, head flow, cubic inches, rpm range, octane etc. He then delivered a perfect cam and never once did him or I talk about cam spec numbers. Then a few years later when I wanted a more race oriented setup he delivered again successfully.
what you are looking for is not an engine that makes peak Hp at 8000 you will want something that makes peak Hp at 6500 but keeps 90% of its power without losing valve control at 8000. If it makes let’s just say 550 Hp at 6500 rpm and 530 Hp at 8000 that’s a win! You aren’t trying to outdo anyone this is about what you want and many people seem to miss the boat on thier opinions. Comparing an iron head SBO to this masterpiece is apples and oranges.
Old March 21st, 2023, 11:54 AM
  #88
Go with the boosted DX 350. with 400 or 425 Old forged crank. Or one from Mark cutlassefi.. Turbo "S71" Olds Engine Build Video BTR Performance Part 1 V8TV.
My builder.
Old March 21st, 2023, 12:40 PM
  #89
Thanks that’s awesome!
Old March 23rd, 2023, 06:40 PM
  #90
Bryant crankshaft small, light and cool. Good for 1400 HP. Crank spacers in. Waiting for heads to come back from T&D for shaft mount rocker fitting. Shooting for May to pick-up. To make you anti EV crazy, I am picking the engine up in my Tesla Y
My new 84 H/O form back in the day.
Old March 23rd, 2023, 07:28 PM
  #91
Out of Line, Everytime😉
olds 307 and 403's Avatar
Nice, car purchase! That crank is so shiny! Love the Tesla pick up too. I plan on picking up my 358 short block, going in the trunk of my Challenger GT.
olds 307 and 403 is offline
Old March 23rd, 2023, 07:57 PM
  #92
My bad, that's my new 84 H/O i bought back in the day. Many of its parts in HighwayStar now.
Old March 23rd, 2023, 10:26 PM
  #93
68post's Avatar
That's one very nice crankshaft ! Weight, rod & main jrnl sizes, stroke ? Really like the center CW's, it looks light also !
68post is offline
Old March 24th, 2023, 07:18 PM
  #94
417 cu in. Spacers going in from 3'' to 2.5'' (3.850 x 1.888 x 1.902 x 350 main, 52.3 lbs. Jim Smaaladen Bryant Racing 1600 E. Winston Road Anaheim, CA 92805) That's even lighter than what Mark sells, he said his was 56#. But at a price.
Old March 25th, 2023, 09:42 AM
  #95
Balance bobweight of 1656 gr.
Old September 18th, 2023, 03:03 PM
  #96
Started machined, Yes!!!! The HP four bolt main caps. Look real nice! From what I can see of them.
Old September 18th, 2023, 03:27 PM
  #97
rickw30's Avatar
" IT'S ALIVE"
Hang in there buddy. It will be worth it.
rickw30 is offline
Old September 18th, 2023, 03:36 PM
  #98
Awesome!
Old September 19th, 2023, 06:53 AM
  #99
My first look at the spacers. .Had to bore a good bit. .160?
Old September 20th, 2023, 01:51 PM
  #100
Did not think about these oil feed holes. Feeding what was the plan for them. Anybody! Bill says it a first for him.
Old September 20th, 2023, 05:21 PM
  #101
cutlassefi's Avatar
They’re just drain holes. All small blocks have them.
cutlassefi is offline
Old September 20th, 2023, 05:33 PM
  #102
rickw30's Avatar
^ correct
John go back to my original ad and read the " " Oldsmobile In Action " article I posted showing these drain holes and special oiling techniques used by F.J. Smith when running these engines. I believe Bill mentions him in his book.
rickw30 is offline
Old September 20th, 2023, 05:35 PM
  #103
My bad, no feed holes to lifters. Working 14-16 hours a day designing is turning my brain to jelly..
Old November 5th, 2023, 03:45 PM
  #104
Big block chevy seal with a quad ring inside. Spacers are in the block!!
Old November 5th, 2023, 03:54 PM
  #105
rickw30's Avatar
Looking fantastic John.
I love it !
rickw30 is offline
Old November 5th, 2023, 04:11 PM
  #106
fleming442's Avatar
That rear seal action is T I T S!!!
fleming442 is offline
Old November 5th, 2023, 04:27 PM
  #107
Agree, everything looks great, love that one piece rear main. Now if we can get a one piece rubber pan gaskets with limiters, we would be set.
Old November 6th, 2023, 08:12 AM
  #108
I have had good luck with pan gaskets. Engine and transmission pans. If I put a very light coat of silicone on both sides. I know that everyone says, do not do. Even the rails of the engine and intake manifold. I also take a center punch to engine and intake manifold rails. Putting many little indents. That keep oil from leaking past.
But not having to pull engine to fix rear seal. Golden!!!
And now the piston. here comes the
comments. My reworked Battan head are like 55cc and with very high lift.
Old November 6th, 2023, 10:57 AM
  #109
68post's Avatar
Your gold seems to be correct and the block is looking great ! Gold must be the easiest color to match for all the paint vendors it seems.
Did you say that this block doesn't have lifter feed oil holes, and that Bill had not seen this before ? (I know I haven't)
68post is offline
Old November 6th, 2023, 12:16 PM
  #110
Good hear, mine seep somewhere almost always. I agree on the RTV on both sides. What pan is going on this beast? My Canton looks impressive but it didn't sit straight on the block. It is not only leaking on the extra temp sensor plug, I see wetness on the pan gasket, haven't even started it! Only the Right Stuff on one side of the gasket. What are those pistons specs?
Old November 6th, 2023, 02:00 PM
  #111
Strong grade of silicone. like 50 year architected grade 100% silicone. RTV has failed me, as many other automotive sealants. Again very thinly. I know guys on here will say. Its bad ideal. I just not going in or under a car to fix a oil leak again. FTS.
The piston, all I know its close to 11.1:1 compression. Batten heads mapped out by Bill T.
Its a Gold color I like Not Old's gold.
Old November 6th, 2023, 02:13 PM
  #112
Old's had many experimental blocks made. He went to put the oil pump drive shaft in. No hole. Had to machine that one too. And one or two other things. T
his gold is what I like. Not Old's gold.
Old November 6th, 2023, 02:18 PM
  #113
Oh, my oil pan.
Old November 6th, 2023, 04:20 PM
  #114
fleming442's Avatar
Indian shellac or Permatex #3 on both sides of the cork works wonderfully. It's messy, but will not leak.
Old November 6th, 2023, 05:02 PM
  #115
I haven't seen Indian Shellac for years up here. I always have a can of Permatex Aviation sealant on the shelf, which apparently is #3. I should have coated the already latex coated Felpro pan gaskets.
Old November 6th, 2023, 05:21 PM
  #116
Messy for sure. I grew up fitting pipe for steam and boilers. Working for my Dad. Old time Grrip sealant (Permatex like). Hard to get off fingers and clothes. Mom would have a conniption fit. If we asked to wash in the laundry. Wrap plumber string on the threads and Grrip. Never leaked. This was way before real teflon tape.
Old November 6th, 2023, 08:21 PM
  #117
68post's Avatar
Whomever's gold it looks perfect !
I sold a special hybrid DX block this year to a board member, but - of course, it was different than this one. I bet nobody can actually know how many versions of special hybrid blocks were made in all. Mine was with .842 lifter bores (unfinished, 842 lifters wouldn't fit), 3.0" mains, and very thick 307 bores. It had the injector pump boss too.
68post is offline
Old November 7th, 2023, 08:00 AM
  #118
Do you have any pictures? I putting everything I have on here for this one. To document as many blocks that Old's made.
VHT SP404 Engine Metallic Gold Flake
Bore - 3.995
Main bearings - 3.00
Lifter bore - .875
Old November 7th, 2023, 10:38 AM
  #119
It must be the lighting. I have that paint on my 358, it is much more gold and brighter than the factory colour.
Old November 8th, 2023, 12:11 AM
  #120
68post's Avatar
Bore - 3.995
Lifter bore - .875
I did send some text pics before the sale, I'll look for those when I get the chance, but it's been just a little while.
68post is offline
Quick Reply: Nascar 350 dx build 8,000+ rpm
