olds motor with no size stamping. what size is it?
Old December 6th, 2012, 04:58 PM
Wildcard's Avatar
ok. i found a olds v8 in a 80s GMC truck at a local scrap yard. it doesnt say 5.0 or 5.7. i didnt get the block number. is there any other way to tell what size the motor is?
Wildcard is offline
Old December 6th, 2012, 05:28 PM
Octania's Avatar
Yes, get the block ID
Or, the heads' ID will probably do, to begin with. On your lower left as yo uview the engine from the side.
Octania is offline
Old December 6th, 2012, 06:06 PM
Eightupman's Avatar
Casting number on the shelf next to the oil fill tube above the water pump will ID the size of the block. Since the heads are interchangeable (for the most part) it's not best to count on them to ID a motor.
The early 80's trucks that came with a diesel were the Olds version. So when the motor gave up the ghost, the logical swap for most was an Olds gas motor. 403s were plentiful back then... Wonder if that truck has the HydroBoost braking system...
John
Eightupman is offline
Old December 6th, 2012, 08:14 PM
Wildcard's Avatar
im gonna get the block number tomorrow and run it after work. it didnt say the motor size were the casting number was. thats what i looked for. i do know its a gas motor.
Wildcard is offline
Old December 7th, 2012, 06:21 AM
Only the late 1970s and up motors have a size as part of the casting numbers. Earlier blocks just have a casting number that can be mapped to the displacement.
joe_padavano is offline
Old December 7th, 2012, 05:01 PM
Wildcard's Avatar
ok. the block casting number is 557751-2B and its in a 76 GMC full size pickup truck. does anyone know what displacement the motor is or how i can find out?
Wildcard is offline
Old December 7th, 2012, 05:22 PM
Wildcard's Avatar
ok. never mind. i ran the numbers. it cam back as GM's most worthless v8. a 260. i defently dont want that motor.
Wildcard is offline
Old December 7th, 2012, 05:35 PM
oldsman72's Avatar
Just did a web search... It's a 77-82 olds 4.3l v8 according to "engineguy".
oldsman72 is offline
Old December 7th, 2012, 07:46 PM
Eightupman's Avatar
Jeeze that thing must have been an absolute JOY to drive...
John
Old December 7th, 2012, 07:48 PM
Wildcard's Avatar
power of a 4cyl and the MPG of a v8
Wildcard is offline
Old December 9th, 2012, 10:35 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Man, even the diesel would have been faster plus twice the mileage. The worst Olds V8 ever. At least the early ones were solid main and had slightly less pathetic heads. There was no upside to the later window web dogs. Similar to the 267 sbc, they were give away motors.
olds 307 and 403 is online now
costpenn
April 30th, 2012 07:40 AM
wagonmaker
July 30th, 2011 03:13 PM
arodenhiser
Wheels and Tires
March 28th, 2011 03:48 PM
coltsneckbob
Drivetrain/Differentials
August 8th, 2009 09:02 PM
blunce
September 10th, 2007 10:17 AM
Quick Reply: olds motor with no size stamping. what size is it?
