port and polish
Old December 6th, 2009, 08:23 AM
dman0712's Avatar
port and polish
i have 72 350 7a heads that i did a port and polish on. ive been told its best not to polish the intake ports. should i just go over them with a heavier grit sandpaper and do i do the entire port or just the side walls?
dman0712 is offline
Old December 6th, 2009, 09:49 AM
70 cutlass s's Avatar
Inside where it is rough is where the air and fuel mix. If you smooth it out you will ruin the heads. You can make the opening bigger use the intake gasket as a template.
70 cutlass s is offline
Old December 6th, 2009, 10:09 AM
Run to Rund's Avatar
Just go over them with a coarse sandpaper roll in a drill or die grinder.
Run to Rund is offline
Old December 6th, 2009, 10:57 AM
dman0712's Avatar
do i do the entire intake port this way? I thought the air and fuel mixed inside of the intake manifold?
dman0712 is offline
Old December 6th, 2009, 02:45 PM
not the valve seats of course. Sure air and fuel mix at the carb, but you don't want to encourage fuel to drop out of suspension along the way. Years ago, Mopar max wedge racers found that the rougher castings actually helped power.
Old December 6th, 2009, 04:22 PM
dman0712's Avatar
ok thanks and do you think my valve springs are ok.
Dual Valve Springs I.D. of Outer Dia.: 1.073"
I.D. of Inner Dia.: .697"
Seat load: 121lbs @1.700''
Open load: 337lbs @1.150''
Coil bind: 1.020''
Rate: 392lbs/in
my cam is a hydraulic roller int528 exh 547 duration is int248 exh254. lsa 110. im going to have it ground down a little more though so my duration will be in the 230's
dman0712 is offline
Old December 6th, 2009, 06:39 PM
cutlassefi's Avatar
You might want to have it ground for more lift as well. If you have good flowing heads lift is horsepower without losing much driveability if any. I have a brand new Erson Hyd Roller for sale if you're interested, 226/234 @ .050, on a 112, .584 lift with 1.6 rockers.
cutlassefi is offline
Old December 6th, 2009, 07:48 PM
dman0712's Avatar
Can my cam be ground for more lift? I know i can reduce the duration.
dman0712 is offline
Old December 6th, 2009, 07:58 PM
cutlassefi's Avatar
Technically yes but it will reduce the base circle.
Old December 6th, 2009, 08:02 PM
dman0712's Avatar
what is the base circle? should i have it ground down. its a custom ground cam so i cant return it
dman0712 is offline
Dan Wirth
Care and Appearance
February 7th, 2017 04:21 PM
35mastr
Paint
October 28th, 2011 05:23 PM
oldsmansugar
Care and Appearance
March 13th, 2010 02:38 AM
Cameo White
April 10th, 2009 05:31 PM
23109 E.O.S.
April 6th, 2009 04:58 PM
Quick Reply: port and polish
