Tick tick tick
Old June 3rd, 2016, 10:05 AM
Copper Nine Eight's Avatar
Knock knock
85 delta 88
307
There is aticking sound coming from the engine. Sound like it's one the driver side of the engine. When it warms up, the ticking gets quiet. It doesn't go away completely. Anyone know what the problem could be? Thanks!
And I think I might have a knock?!?! Not sure if I'm just paranoid or if I'm really hearing a knock!
Copper Nine Eight is offline
Old June 3rd, 2016, 10:30 AM
442Harv's Avatar
Sounds like a loose exhaust manifold.
442Harv is offline
Old June 3rd, 2016, 10:46 AM
Hookers under Hood
76olds's Avatar
I agree with 442harv, if you can feel around the exhaust manifold quickly after start up from cold.
The knock could be a bad motor mount or trans mount.
I would check the oil, do an oil change and see if its clean.
Eric
76olds is offline
Old June 3rd, 2016, 11:28 AM
._.
85 delta 88
307
So here we go. This is my car and the knocking sound. What does it sound like to you guys?!
https://www.youtube.com/watch?v=axk4...ature=youtu.be
Old June 3rd, 2016, 12:17 PM
I merged your threads and fixed your link. Its better to keep all the info in one place instead of opening multiple threads.
oldcutlass is online now
Old June 3rd, 2016, 12:29 PM
Thanks! Sorry about the multiple threads
Old June 3rd, 2016, 12:47 PM
Hookers under Hood
76olds's Avatar
Man, I hate to say this but it sounds almost like a connecting rod. Was the hood up or down in the running clip?
76olds is offline
Old June 3rd, 2016, 12:56 PM
It was from the bottom of the car. You can hear it better from the bottom of the car or if you stand back.
Old June 3rd, 2016, 12:59 PM
Rustbucket2's Avatar
I clicked on you tube link and ended up with china! I think
Rustbucket2 is offline
Old June 3rd, 2016, 01:03 PM
Lol wth. Well that ain't right
Old June 3rd, 2016, 01:46 PM
without hearing it, the first thing I would check is flywheel, I had one that had come lose and sounded like a knock in bottom of motor.
Old June 3rd, 2016, 01:55 PM
That is definitely a noise. However can't really make out exactly what it is from the video. What happens when you increase the rpm's, does it get louder?
Old June 3rd, 2016, 02:00 PM
When I increase rpm's, I stop hearing it but I'm pretty sure it's because of the fan and belts drown out the noise. And when I decelerate the sounds can be heard again.
The speed of the knocking sound increases when I accelerate and decreases when I decelerate. And when I put it in park, at idle it speeds up.
Old June 3rd, 2016, 02:09 PM
What weight and brand oil are you running? What is your oil pressure?
Old June 3rd, 2016, 02:26 PM
10w-30. Oil pressure, I have no idea.
Oh and the brand is pennzoil. IF YOU RECOMMEND A DIFFERENT WEIGHT AND BRAND PLEEEEEAAAAAASE TELL ME. I stood in auto zone looking a oil for 30 minutes trying to pick smh. And that's what I ended up with.
Old June 3rd, 2016, 02:29 PM
That would make some since. The transmission was rebuilt 2 months ago and I swear I don't remember this knocking BEFORE that. I'm still under warranty so I think I will take it up there Monday and see if they will tighten it down. And hope that fixes the knock.
Old June 3rd, 2016, 03:37 PM
I'd pickup a cheap mechanical oil pressure gauge and hook it up and see what it is cold and hot.
Old June 3rd, 2016, 04:37 PM
Will do sir!
Old June 3rd, 2016, 06:39 PM
Sugar Bear's Avatar
If you can hear the knock as the key is turned off but the engine has not stopped all movement yet, it is likely loose torque converter bolts.
Sugar Bear is offline
Old June 3rd, 2016, 10:07 PM
Ahhhhh yes I can! I will go have the people that rebuilt my trans to look. Thanks man! And everyone. I LOVE THIS FORUM!. Hopefully that's my problem
Old June 6th, 2016, 07:13 AM
well, was it the bolts?
Old June 6th, 2016, 12:06 PM
Literally at the shop right now finding out! Lol I praying it is. Will let you know when I find out!! Pray for me lol
Old June 6th, 2016, 03:30 PM
They said it wasn't. Said it's my engine :/ horrible engine knock!
Old June 6th, 2016, 03:38 PM
Hookers under Hood
76olds's Avatar
Ahh that sucks, I thought it sounded like a rod. Are you still trying to diagnose the problem ?
76olds is offline
Old July 1st, 2016, 11:24 PM
Randrup's Avatar
So...?? Did you find the problem? :-)
Randrup is offline
Old July 14th, 2016, 06:09 PM
Gearhead in training
Northern Custom Cruiser's Avatar
Ive got a 307 in my '83 custom cruiser and its got a similar knock that acts the same but yours sounds much meatier
Northern Custom Cruiser is offline
Old July 14th, 2016, 07:09 PM
W30
truckman5000's Avatar
Check the transmission yourself, or have someone else do it.
Im a plumber, people think plumbers rip people off....how about transmission places, im better at transmissions than 4 trans. shops here.
Also, an engine knock will get louder with time, how many miles since the trans.
truckman5000 is offline
Old July 14th, 2016, 07:27 PM
A little over 1000
Old July 14th, 2016, 07:33 PM
I replace my egr valve and the knock isn't as loud. My dad said I should go with a straight 30w oil.
See if your egr valve is bad. You can check by removing the egr valve and compressing it by hand so that you hear air and cover the small hole that's on the part the hose goes over and if the valve doesn't stay compressed then it's most likely bad.
That's if you didn't know that already!
The new egr valve helped my knock!
Old July 14th, 2016, 08:23 PM
Are you sure you arnt referring to the choke pulloff? On the passenger side of your carb?
Old July 14th, 2016, 08:59 PM
  #31
I'm sure. It's on the driver side right by the valve cover. I'm serious haha! It helped my knock! Luck maybe? Who knows ha
Old July 14th, 2016, 09:33 PM
  #32
I was informed to whack it with a hammer... But i guess your method works as well xD
Koda
December 3rd, 2013 08:50 PM
442buyer
January 7th, 2012 06:43 PM
Tangovino
July 31st, 2009 03:20 AM
cmurray
February 16th, 2009 06:28 PM
442buyer
March 31st, 2007 06:46 AM
Quick Reply: Tick tick tick
