350 balancer question
Old March 5th, 2010, 11:09 AM
I was going thru my pile of engines and found a 350 with a larger (thicker) balancer than my 455s. Is the engine anything special? Unfortunately, this is the only small block I have to compare it to. It is the same diameter, just thicker than the 455 and 425 stuff I have.
matt69olds is offline
Old March 5th, 2010, 11:14 AM
Eric Anderson's Avatar
w-31 balancer/engine?
Eric Anderson is offline
Old March 5th, 2010, 11:18 AM
Dimensions:
Outer step: 7.140" o.d., .680" thick.
Inner step: 6.485" o.d., .1.155" thick.
Outer step recess from hub: .250"
Weight: 12 lbs., 3 oz.
Note: There are several "stepped" style factory balancers. Be sure to check the sizes listed above to confirm a W-31 balancer.
Old March 5th, 2010, 12:35 PM
Mine is smooth, no step. Didn't think I was lucky enough to find a W-31 shortblock. If so, you can bet your bottom dollar I would have bought a lottery ticket before my luck ran out!
Old March 5th, 2010, 01:32 PM
Lt. Buzzkill (ret.)
copper128's Avatar
Seems like a lot of the earlier 350 (68-70) were bigger than the usual balancers, but not nearly as big as the W31 unit.
copper128 is offline
cheven
June 27th, 2012 06:06 PM
84oldsDelta88
April 25th, 2011 06:39 PM
dallasite21
March 20th, 2011 03:02 PM
jerseyjoe
January 6th, 2011 06:51 AM
crazy'boutOlds
August 9th, 2009 11:17 AM
Quick Reply: 350 balancer question
