1981 Toro engine decals
quick question
seeking: (1) small air cleaner decal NU "keep your gm vehicle all gm"
(2) decal over top of radiator shroud " gm vehicle emission information" "emission hose routing "
diagram.
(3) black flex plastic hose from end of air cleaner nozzle, to air inlet box next to upper radiator hose.
( my guess 3 inch diameter )
anybody have a source ?
dal442
diagram.
dal442
He won't have any of those decals most likely because I haven't made any yet. I believe the 81 air cleaner decals had the bar codes on the RH side. Dr. Decal doesn't carry any of the bar coded "Keep your GM car all GM" decals nor the 81 engine emission decals.
For the hose, it's called an ADAPTER, part number 22505347. E body gas engine only. 1981-1985 used the same part. Has a clamp on the front and a plastic bend snap-in part on the air cleaner end side. It's weird because the air cleaner inlet has a downward slope from the air cleaner housing.
Just got done making some 70 Vista jacking instructions and stowage decal set for someone. Nobody had these in a complete set either...until now. Plus got some 70 Vista tire presssure door jamb decals in case anyone needs any.
