66 Wiper motor removal
Old June 9th, 2022, 12:55 PM
ourkid2000's Avatar
Good day all,
Looks like my wiper motor isn't working on my 66' Toro. Seems that the wiring to it is good but it doesn't want to start up. I was thinking about taking it apart and seeing if I can repair but I can't really tell how to get it out. The connections to the wipers are under the cowl.
Anyone have any suggestions how to remove? Does the whole cowl have to come off? There is a grill panel that would also give me access but I can't see how to get that off either.
Thanks again!
ourkid2000 is offline
Old June 9th, 2022, 03:28 PM
Before you take everything apart, get a schematic and make sure you have power (which is constant with the key on) and the grounds provided by the switch in the dash.
oldcutlass is offline
Old June 9th, 2022, 03:37 PM
ourkid2000's Avatar
I do have 12v power at the center terminal.
I used the test procedure in the manual where you disconnect the car's wiring and jump power and grounds to the 3 terminals to force the wiper motor to run. It does not run. I gave it a tap with a rubber mallet as well while it was powered up, no response.
Old June 9th, 2022, 06:41 PM
2blu442's Avatar
Yes, you have to remove the cover between the hood and windshield. I have a couple of those loose, if it would help I could take pictures showing where the fasteners are.
John
2blu442 is offline
Old June 9th, 2022, 07:00 PM
ourkid2000's Avatar
John
That would be awesome! Thanks so much!
Old June 10th, 2022, 04:44 AM
Is the wiper motor ground strap in place? The wiper grounds to the body, but since it is mounted in rubber bushings, there is a separate ground strap that runs around the outside of one of the bushings. Try running a temporary ground wire from the motor housing to a good body ground before buying any new parts.
joe_padavano is offline
Old June 10th, 2022, 08:05 AM
ourkid2000's Avatar
My old school test light does light up brightly when I test from the wiper motor body to battery positive so I'm thinking my wiper to ground connection is good but I will give it a try.
Old June 10th, 2022, 08:09 AM
Yes, that would indicate an adequate ground.
Old June 10th, 2022, 10:55 AM
2blu442's Avatar
If your paint is nice you'll need to be careful with this process. You need to remove the two wiper arms. Then there are 7 small screws, two horizontal and 5 attached vertically. I think these have a bolt style head that takes a 1/4" socket/wrench. Here's a series of pictures showing where they are.
2blu442 is offline
Old June 10th, 2022, 01:13 PM
ourkid2000's Avatar
That is great info, thanks so much. My paint is not good at this time. I'm planning on fixing all the mechanical issues prior to painting.
Old June 10th, 2022, 02:30 PM
Oldsdruid
rocketraider's Avatar
Do yourself a favor and get yourself a wiper arm puller. So much easier than trying to pry off with a screwdriver or whatever. Any auto parts store or online should have one or the other of these. Might help to spray a little penetrating oil on the splines first.
rocketraider is online now
Old June 10th, 2022, 02:37 PM
There are two tricks to pulling the wiper arms, The first is to get this little spring clip disengaged. The second is to pull up on the side opposite the arm, as the spring pulling down on the arm causes the hub to **** on the splined shaft. The plier-style tool Glenn showed works pretty well to do both of these actions at once. On the other hand, I will admit that for stubborn wiper arms I've sometimes had to resort to a large screwdriver, a small block of wood, and a towel to protect the surface. If you do that, pry under the side opposite the arm, though occasionally you need to pry under the spring clip initially to get it popped up out of the groove in the shaft, then move to the other side.
Old March 6th, 2024, 06:48 PM
mzack66442's Avatar
I know this is old, but, Jie, you are awesome, thanks for all you do to help us with our Oldsmobiles!
mzack66442 is offline
RandyS
May 10th, 2021 02:26 PM
bobfo1
August 10th, 2018 04:36 PM
Globeguy
February 8th, 2018 07:07 AM
bw1339
October 10th, 2015 04:13 AM
BigWelder036
August 11th, 2012 12:58 PM
Quick Reply: 66 Wiper motor removal
