Brake drum question...'69 Toronado
Old October 6th, 2014, 08:28 PM
Ronschwartzsr's Avatar
My '69 Toronado is equipped with front drum brakes. I wanted to pull a drum off to check my linings today but had difficulty trying to remove the drum. My question.....does the large 1 1/2 inch spindle nut need to be removed (it's on extremely tight). I couldn't tell if the center hole of the drum was outside or behind that nut.
Ronschwartzsr is offline
Old October 6th, 2014, 09:19 PM
After reading some past forum posts regarding brake drums, it looks like I'm trying to determine if my drum and Hub are one piece or if their is a separation there that I just cannot see?
Any help will be appreciated....thanks.
Old October 7th, 2014, 03:54 AM
Oldsdruid
rocketraider's Avatar
Hub and drum are separate. You do not need to pull the spindle nut. The Toro uses the same brake drums front and rear.
You HAVE backed off adjustment on the brake shoes, right?
Spray a little PB Blaster around where the drum meets the spindle and tap around there to break the bond. Rent a brake drum puller if needed. Worst to worst, a little heat will break them loose.
rocketraider is online now
Old October 7th, 2014, 07:57 AM
waterzap's Avatar
They will come off, but sometimes can be a pain. See if you can heat up the drum a bit. If it expands, could come off easier.
waterzap is offline
Old October 7th, 2014, 08:21 AM
Tap it a couple of times on the side with a hammer while pulling back. You may have to loosen the adjuster barrel for the drum to slide easier.
oldcutlass is online now
Old October 7th, 2014, 09:37 AM
Octania's Avatar
you may have to loosen the adjuster A LOT. Like all the way.
Octania is offline
Old October 7th, 2014, 05:40 PM
Thanks for your responses.....I'll be be getting back to the job in a couple of days....will let you know how it goes!
Old October 8th, 2014, 07:44 AM
twintracks's Avatar
The center nut is holding the axle in place. The drum will come off with persuasion. The hub & axle stay in place. Try to save your drum. The ones that Napa sells are too small, but with the correct part number.
Also, there should be a cotter pin in your axle nut.
twintracks is offline
Kilmster
Brakes/Hydraulic Systems
August 6th, 2014 05:41 PM
yeahbuddy
January 15th, 2014 02:10 PM
68RocketAction
January 2nd, 2014 06:49 PM
jon69olds
Wheels and Tires
February 11th, 2011 11:57 AM
EightballZ
September 28th, 2010 01:45 AM
Quick Reply: Brake drum question...'69 Toronado
