Gasket material for firewall
Old April 9th, 2024, 07:18 AM
Jetmek's Avatar
I need to remove the HVAC units from the firewall. They look like some kind of sponge rubber gaskets were used. Are they available new or what should i use as a substitute? Thnx
Jetmek is offline
Old April 9th, 2024, 07:35 AM
I'd use self-adhesive foam tape available at the hardware store.
https://www.homedepot.com/p/Frost-Ki...534H/202262324
Olds64 is online now
Old April 9th, 2024, 07:49 AM
FStanley's Avatar
https://www.summitracing.com/parts/o...UaAr9CEALw_wcB
FStanley is offline
Old April 9th, 2024, 07:56 AM
Jetmek's Avatar
Awesome ! Thanks!
Jetmek is offline
Old April 9th, 2024, 08:00 AM
Jetmek's Avatar
those look like all A body applications
Jetmek is offline
Old April 9th, 2024, 12:49 PM
Which is all you are going to find from sources like Summit.
joe_padavano is offline
Old April 9th, 2024, 12:59 PM
Jetmek's Avatar
MSC has sheets of 1/4” open cell neoprene. Looks like i gotta make my own
Jetmek is offline
Old April 9th, 2024, 07:23 PM
Gary
VC455's Avatar
Open cell is not waterproof. Use closed cell.
Neoprene will eventually take a set, oxidize, and deteriorate (the way the factory gasket did).
Because of that, I experimented with using closed cell silicone foam from McMaster-Carr during an A/C rebuild 15 years ago. It still has flexibility.
VC455 is online now
Old April 10th, 2024, 03:09 AM
Exactly what I did as well. Also got mine from McMaster Carr.
maineolds
July 17th, 2021 03:47 PM
Oldssupreme
July 27th, 2016 03:56 AM
fatgroundhog
June 14th, 2015 03:04 PM
spyke
March 28th, 2013 08:13 PM
Joel
March 7th, 2011 10:45 AM
Quick Reply: Gasket material for firewall
