Manual antenna replacement
Old January 19th, 2021, 01:11 PM
sgolds's Avatar
I just have the external antenna base with the threads, need to find an antenna that will screw on. Will any aftermarket antenna work? Anyone done this on a 66 Toronado?
sgolds is offline
Old January 19th, 2021, 04:27 PM
Yellowstatue's Avatar
It might just need a gasket and correct chrome base and metal nut to hold the base to the fender, and then an Olds antenna that slips into the base and a black plastic nut to hold it firmly down. Try that.
Yellowstatue is offline
Old January 20th, 2021, 09:17 AM
sgolds's Avatar
Where can I get the antenna from? Is it the same as the one on a Cutlass etc?
sgolds is offline
Old January 20th, 2021, 10:31 AM
The Cutlass profile is different from a Toronado and the tip is different, but they should be interchangeable.
Old January 20th, 2021, 01:43 PM
sgolds's Avatar
Can anyone post a pic of the correct antenna mast, especially the threaded part?
sgolds is offline
Old April 18th, 2023, 04:44 PM
sgolds's Avatar
Getting back to this thread,
I think I found the remains of the original antenna. I tried to put it in the base but it seems to be too tight to fit all the way in. Is it normal to be a very tight fit to get the mast into the base, or should it go in smoothly and then be held on with the black plastic nut?
sgolds is offline
Old May 2nd, 2023, 01:07 PM
sgolds's Avatar
Some websites show it as a "press fit", how would you put the mast in that way? Do you have to hammer it in or something?
sgolds is offline
Old May 3rd, 2023, 05:07 AM
Don't do anything to damage the antenna. Directions for install should be in the Chassis or Factory Service Manual.
If you aren't doing a concours restoration I suggest getting an aftermarket antenna. You might consider this company:
https://www.theantennasource.com/
Olds64 is offline
indy500
November 25th, 2018 06:11 AM
drkearnel
January 12th, 2018 08:19 AM
Delta88conv455
August 24th, 2013 02:51 PM
Hank
January 29th, 2013 06:06 PM
4-Speed
August 23rd, 2010 05:52 PM
Quick Reply: Manual antenna replacement
