1961 Dynamic 88 trans fluid leak at speedo cable connection
Old July 19th, 2023, 05:46 PM
61olds88's Avatar
1961 Dynamic 88 trans fluid leak from speedo cable? (photo)
Hello. Newbie here. Just picked up a 1961 Dynamic 88 with original engine and automatic trans. It appears to be leaking transmission fluid from some sort of joint or connection in the middle of the speedometer cable. See attached photo with arrow pointing to where the leak is. Im having a hard time finding what I need to repair this. I assume a new speedometer cable? The speedometer does work properly otherwise. Can anyone point me in the right direction or have part numbers for what I may need? Im sure this wont be my first post as there is a list of items I need to address on the car one by one. Thanks in advance!
61olds88 is offline
Old July 19th, 2023, 06:43 PM
61olds88's Avatar
Edited my original post. It's not leaking at the trans connection. Its leaking from the joint in the photo in the middle of the speedo cable.
61olds88 is offline
Old July 19th, 2023, 08:28 PM
61olds88's Avatar
Now I’m even more confused. Showed a guy that photo and he said no way is it leaking from there as the cable itself has no sealing function. It must be leaking from the connection/driven gear at the transmission. Weird because there is no fresh fluid there but definitely fresh fluid further down the cable near the point I circled. Anyway, where can I get a seal kit for the driven gear/trans connection point?
61olds88 is offline
Old July 20th, 2023, 02:48 AM
That's a weird place for a transmission fluid leak. I thought the speedometer on your Oldsmobile was driven off of the front driver's wheel. You can check out Fusick to see if they have parts for your car.
https://www.fusickautomotiveproducts.com/
Here's a place to get transmission parts for your Oldsmobile if you ever have to go further in your restoration.
https://www.fatsco.net/
Olds64 is offline
Old July 20th, 2023, 08:28 AM
Phantom Phixer
Charlie Jones's Avatar
Originally Posted by Olds64
I thought the speedometer on your Oldsmobile was driven off of the front driver's wheel. /
That was only on '63 thru '70 models.
Charlie Jones is offline
Old July 20th, 2023, 08:41 AM
Phantom Phixer
There is an "O" ring and a seal at the speedo gear.
The fluid is leaking from there, and is running down the inside of the cable.
Old July 20th, 2023, 08:51 AM
Thanks for setting me straight Charlie.👍
Olds64 is offline
Old July 20th, 2023, 09:18 AM
61olds88's Avatar
Thank you, Charlie! Any idea where I can buy those o-ring and seals? Doesnt seem to show the part numbers.
61olds88 is offline
Old July 20th, 2023, 09:50 AM
Phantom Phixer
The part numbers are here in group 4.338.
Old July 20th, 2023, 09:55 AM
Phantom Phixer
Looks like 584059 .
Here's a link to FATSCO
Speedometer Seal (fatsco.net)
Old July 20th, 2023, 12:36 PM
61olds88's Avatar
Cant thank you enough! This American classic is not my normal wheelhouse. Im used to old Volkswagens, so its a bit of a learning curve for me to find parts and part numbers.
61olds88 is offline
Old July 20th, 2023, 05:14 PM
Phantom Phixer
These free downloads will help.
1963 Oldsmobile Parts and Accessories Catalog (Chassis Edition) - ClassicOldsmobile.com
1963 Oldsmobile Parts and Accessories Catalog (Body Edition) - ClassicOldsmobile.com
Old November 29th, 2023, 09:26 AM
WikedOldsmoileSupe88's Avatar
I have the same issue with my car. I changed the main o-ring seal on the cable but not the small o-rings. Seems odd that the fluid leaks out of the plastic cable housing. Is the material porous?
To change the internal seals, I'm assuming you disconnect the speedometer cable from the transmission. But where is the small O-ring located. Is it in the end of the cable?
Thanks.
WikedOldsmoileSupe88 is offline
skiflyer
August 4th, 2023 05:08 AM
ripper27
February 24th, 2019 08:26 AM
ripper27
July 9th, 2018 02:17 PM
Mybaby67
October 27th, 2014 09:35 PM
bunga
December 14th, 2013 11:25 PM
Quick Reply: 1961 Dynamic 88 trans fluid leak at speedo cable connection
