1964 Super 88 trans swap with 1960 88 trans
Old May 14th, 2010, 11:53 PM
Rich from Las Vegas
64Super88's Avatar
When I got my car the trans was in pieces in the trunk... I picked up another trans yesterday but it's from a 1960 Olds 88... Its obviously shorter and I'm not sure what model trans.... It came mounted to a 371 w/ a 2 bbl carb so i assume it will bolt to my 394 in the 64. I stole this pic from another "help me ID" thread but it looks to be the same trans...
What model is this?
Is this a bolt on replacement?
What shift pattern does it have?
Will I need to modify my column shift?
It looks to have a bolt on yoke?
Is that a real torque converter?
Is the starter the same from 1960 to 1964?
Is the lower bell housing the same?
I will clean up the actual trans and see if there is an ID tag but it does like like the one above. I hope I can just swap it in and get the car running and driving again....
64Super88 is offline
Old May 15th, 2010, 07:24 AM
Oldsdruid
rocketraider's Avatar
64 uses Roto HydraMatic or "Slim Jim". 60 uses the 4-speed Jetaway Hydramatic. Jetaway is a better transmission and will bolt to your 1964 engine but may not fit in a 64 car without modifying the transmission tunnel. Shift pattern is the same, but Jetaway has a fluid coupling same as a SJ.
There's a couple folks on here who are very good with HydraMatics and interchange. Hopefully they'll see this thread and give you more info than I've been able to.
rocketraider is offline
oldzkool
January 10th, 2014 05:54 AM
tailfins
May 11th, 2013 05:06 PM
tailfins
January 23rd, 2009 11:58 PM
bschubarg
June 14th, 2006 09:26 AM
MRS055
June 9th, 2006 07:15 PM
Quick Reply: 1964 Super 88 trans swap with 1960 88 trans
