2-Speed (3-Stage) Jetaway Trans?
Old August 23rd, 2010, 04:03 PM
J'ville's Avatar
My 64 330 F-85 has the Jetaway trans that works flawlessly. However I have given up on chasing fluid leaks. After investing $300 to have all the gaskets and seals replaced, I still get drips. Now I just lay down puppy training pads that catch and absorb the drippings. But I am open to any suggestions that might be of help. Incidently, those training pads work great at catching any form of fluid leak and actually freshen the air in a garage. I thought of inventing a full size catch pad but I am sure that it would never fly due to EPA disposable issues. Thanks!
J'ville is offline
Old August 23rd, 2010, 09:54 PM
Just the facts...
BILL DEMMER's Avatar
iirc, there was a "case porosity" issue with some of these trannys.
can you see where the fluid is leaking from?
bill
BILL DEMMER is offline
Old August 24th, 2010, 10:16 AM
J'ville's Avatar
Appears leaking from the frontal area. Around speedometer cable seal which was supposively replaced.. Should trans go out, I will go with either one of the R's or TH-350. I understand the Jetaway (Turbine 300), although limited by 2 gears, has much less para-power loss than the just mentioned. Thanks again.
J'ville is offline
dabull55
September 1st, 2013 08:22 AM
Jamesbo
Paint
66
October 30th, 2010 01:04 PM
scubastever
Paint
September 17th, 2009 08:08 AM
jeffreyalman
August 16th, 2009 05:56 AM
TECH9TWISTA
February 12th, 2007 10:58 PM
Quick Reply: 2-Speed (3-Stage) Jetaway Trans?
