68 Cutlass Supreme 2 Speed Jetaway fluid changing
Old January 2nd, 2014, 04:58 PM
yeahbuddy's Avatar
You guys have walked by through changing almost all the other fluids in my 68 Cutlass w/ a 2 speed Jetaway transmission and 350 Rocket. I am wondering if the transmission fluid change is as easy as the differential oil.
-Drain/remove pan
-Remove and scrape the gasket residue
-Clean out pan with brake cleaner
-Install new gasket with rtv
-Reinstall pan
-Refill tranny fluid (4 quarts?)
Am I missing something here or good to go.
yeahbuddy is offline
Old January 2nd, 2014, 05:03 PM
Might want to pick up a transmission filter.
oldcutlass is offline
Old January 2nd, 2014, 05:04 PM
yeahbuddy's Avatar
Whats the process of changing it out? First time removing the transmission pan.
Old January 2nd, 2014, 05:19 PM
It's pretty easy, just pushes on. It comes as a kit with a pan gasket.
Old January 2nd, 2014, 05:28 PM
Old School Olds
tru-blue 442's Avatar
Hopefully it will be a cork/rubber composite
gasket. No need for sealer with the right
torquing.
Start by removing bolts from one corner and
loosting the rest some. Don't forget a catch pan
to catch some of the oil.
1st timer huh? It will be messy. Try to pull it off
staight down and level after removing some of the
fluid. Let us know how it goes, old clothes and plenty
of grease rags.
tru-blue 442 is offline
Old January 2nd, 2014, 07:33 PM
yeahbuddy's Avatar
Thanks guys. I think this is what I need and I'll be good to go.
https://www.yearone.com/Product/1964...lass-442/9293n
Old January 2nd, 2014, 07:48 PM
You can probably get one through your local auto parts store and save the freight charge.
Old January 3rd, 2014, 09:15 AM
I don't typically use RTV along with the pan gasket. I'll just use some gasket tack on the pan rail to hold the gasket in place during installation. Also, don't over-tighten the pan bolts, which will distort the pan can cause leaks. Use a torque wrench to the factory spec. You will likely need to retighten the bolts after a while as the gasket compresses and relaxes.
joe_padavano is offline
Old January 3rd, 2014, 09:50 AM
yeahbuddy's Avatar
Any idea what NAPA would carry the filter under? I found a Felpro gasket
http://www.napaonline.com/Catalog/Ca...625_0147690471
Old January 3rd, 2014, 09:51 AM
yeahbuddy's Avatar
I will look up the torque specs in my manual. Thanks.
Old January 3rd, 2014, 10:06 AM
The NAPAOnline website doesn't list a filter for the ST300. The Fram P/N is FT1014. RockAuto lists them under $3, gasket included. I attempted to cross this part number at the NAPA website with no success. You might try having them cross it in the store. Advance Auto also lists the filter under their Pro King line.
Old January 3rd, 2014, 10:08 AM
yeahbuddy's Avatar
There are actually 2 Wholesaler Closeouts on rockauto...one from GK Filters for $2.88 and another from Pioneer for $1.88. Never heard of those brands before though. I will try to find a part number for a local store first.
Found these with your part number. The Wix kit comes with a 12 hole gasket though which needs to be the 14:
http://www.oreillyauto.com/site/c/de...keyword=ft1014
CubanPete
January 20th, 2014 03:24 PM
yeahbuddy
Drivetrain/Differentials
21
October 22nd, 2013 07:00 PM
68oldscutlass
17
March 22nd, 2013 05:37 PM
Bottoms
September 29th, 2010 07:34 AM
cfair
Brakes/Hydraulic Systems
June 8th, 2009 12:37 AM
Quick Reply: 68 Cutlass Supreme 2 Speed Jetaway fluid changing
