Clunk from yoke
Clunk from yoke
Ok, so I've been hearing a clunk when the car goes into gear, starts from a stop, or I shift into gear. I'm not even really sure where to start to fix this as I'm pretty sure there is way to much play in the yoke *at the transmission. Video is included. Thanks
ETA: Really looking for more Youtube videos or something that has a walkthrough of fixing if possible.
Be SURE it's not a worn u-joint, which is the most likely cause. If that's the case, it's an easy fix. If the slop is really in the rear axle, it could be worn bearings or worn gears. Either way, that's a rebuild of the rear end.
Sorry I wasn't clear enough. The play is coming in where the yoke meets the transmission (why I included the video.) You can hear it about a second and a half after I switch between reverse and drive in the video.
The only way there's "slop" in the trans is if the planetary gear sets are worn. I suspect that is not the cause of the clunk. I couldn't get the video to play without downloading and saving it first, and I was not inclined to do that on my computer.
https://drive.google.com/file/d/11md...usp=share_link Testing to see if this works maybe. It works for me at least.
Definitely a bad UJoint, really bad.
Get under it and grab the shaft and wiggle. I'm surprised it hasn't exploded yet or vibrated you out of the car at highway speeds.
Do both ends at the same time.
Buy Spicer or other USA-made joints. Use blue Loctite on the saddle clamp(cleaned) bolts.
Pretty sure it's original, the car basically sat for 20 years after my great grandmother passed and I don't think my uncle or grandfather did much to it after that. I need to do the front bushings as well it looks like and while tie rod ends passed inspection may look at doing those as well maybe this year.
tcolt
May 19th, 2016 09:08 PM
