Installing a Dual Gate on a 70 442 from an automatic console shift need help!!!
Old May 27th, 2020, 02:09 PM
ethelwulf's Avatar
Ok I’m trying to round up the last parts needed to swap my 1970 442 console shift automatic to Hurst Dual Gate. I need the screws to fasten the shifter to the car, the screws to attach the neutral safety switch bracket to the shifter mounting bracket, the pin and clip to attach the neutral safety switch to the shifter and the pin and clip to attach the shifter cable to the shifter. Any help would be greatly appreciated.
ethelwulf is offline
Old April 24th, 2022, 07:16 PM
tkcutlass's Avatar
I am in the process of doing the same thing and need the same parts you shown above, including the NSS brackets.
Got a source?
tkcutlass is online now
Old April 25th, 2022, 07:09 AM
ethelwulf's Avatar
This is the guy I ended up getting my pins from hopefully he can do the same for you…..his name is Mike mjsiedl@megavision.com Good luck
Old April 25th, 2022, 07:45 AM
4speed455's Avatar
https://www.shifterdoc.com/productca...0060-p1747.htm
You can get the pin here. As far as the NSS, I took the easy way out when I converted to dual gate and I used the column mounted setup that column shift and 71-72 console shifters used. I think you would need a different harness though.
4speed455 is online now
yeahbuddy
May 15th, 2020 05:35 PM
yeahbuddy
April 14th, 2020 01:00 PM
yeahbuddy
March 17th, 2020 11:03 AM
RetroRanger
February 28th, 2014 06:41 PM
Nickthefish
October 18th, 2012 09:57 AM
Quick Reply: Installing a Dual Gate on a 70 442 from an automatic console shift need help!!!
